Link to Good Subwoofer box for 2016 Crew Cab?
BWL
Embrace the skeptisism
BC Canada
Don't disagree. Just depends what you want to get out of your system. For that space custom fibreglass and a pair of high end 10s are probably the best you can get for all around sound due to airspace restrictions. 12's require more space to perform well except for certain subs tailored for smaller airspace, but those aren't the top line typically. I have the JL box in my truck and it's all I need.
Chief_6.7
Can't go wrong with this bad boy, Foxbox Dual 12s in my 2017 CCa7cac0d27dcb1f46e857b703b60a8510.jpg
Sent from my iPad using Tapatalk Pro
That just looks bad a$$...... is it all finished yet. How does it sound? I can just imagine if my 1 10” alpine sounds killer I can only imagine these. Nice box brotha!!!!!!
sumgruuvz
I vote for the foxbox. I have one with an RE Audio SCX10 and it sounds damn good. I listen mostly to rock and metal and the kick drums thump good and solid. Not sloppy at all with my sub. Make sure if you go this route, make sure the airspace is compatible with the enclosure. The enclosure airspace is .95 cuft.
Chief_6.7
So does anyone have a hookup on who can make some spacers out of aluminum or steel to duplicate the fox box MDF ones. I’ll just feel better if it was made out of aluminum or steel?
BWL
BC Canada
With a grinder and cut off disc, drill with 1/2" drill bit and a little patience you can make your own. Just order 2" flat bar in the thickness you want. If you have the wood ones they make a good template for where to drill and recess. If you get them cut to length where you get the material then all you need is a drill and drill bit and you could file the sharp edges.
BWL
BC Canada
Local steel supplier or machine shop. If none available look for welders in the area as they'd know where to get the stuff.
appzattak
Jerome, Idaho
Yes finally finished! Sounds amazing....still gotta fine tune some amp setting but it is rocking!
sueperfan
Milliken, CO
So with these sub boxes, is the back seat still usable? I can't tell from the pictures in these posts. I am looking to add subs to my truck but don't want to lose my back seat!
BWL
BC Canada
Yes, still use able. In my case once I make a few adjustments even my fold out floor will work.
Bessington
Bessington
Shadyside, Ohio
Thanks for all the info everyone. The subwoofer project is on hold unfortunately for now since someone who just got their license decided not to look both ways before pulling out on the road.
TomT
SoCal/OC
Oh crap!
Bessington
Bessington
Shadyside, Ohio
I just made my first payment too. It's in the hands of insurance now. I'm just hoping when it's fixed it drives like nothing happened.
Steve Holtz
