corneileous
- Sep 6, 2016
- 6,852
- 3,918
- Location
- Podunkyville, OK
- 2018 Ram 1500 Limited 4X4
- Hemi 5.7
ADDED: OK, I have a MY 19 Bighorn, keyless start, no passive entry. Turn off truck, put fob on seat, lock close doors. Beep 3 and open. But on third try, vehicle stays locked.
Start truck, put key fob on seat, push lock button down on door, close door, door locks with truck running.
I’m not sure if passive entry would make a difference or not- really don’t know why it would in the first place but when you say you start the truck in your second paragraph and verify that the door stays locked after you manually lock it from the inside and close the door, is that when you started it with the ignition, or after you’ve remote started it? Only reason I ask that is because even though I’ve verified it with my truck while having passive entry, that if I put in and leave the key is inside the truck after it’s been remote started, and I accidentally push the interior lock button and close the door, I can lock myself out that way.
I haven’t tried it yet the other way, with the truck running and not remote started....
