Dragonmom20
So I have a 2017 Ram 1500 5.7 123k miles . This problem is getting worse not better. Sometimes when I go to start my truck it either cracks and dies then 2nd crank it will have a super long crank before starting unless I push on the gas then it starts faster. Sometimes it will just crank long right from the start . I do cycle the key just like a diesel, so turn it to the on position then let it "wake up" then crank . Before I could get it to start okay almost every time, now even doing that is a gamble. I have taking it to dodge which they recommended a fuel pump even after I told them it was already replaced. So now im 3 fuel pumps in , new purge value and a fuel pump control module replacement. Needless to stay im tried of pulling the bed off my truck. Dodge said it was fuel pump is bleeding fuel pressure back to the tank. purge valve is sticking open at times allowing fuel vapor to essentially flood the engine. No codes and at a lost of what to do next. Should I just do fuel injectors??
