My Build So Far
Josh88
Nh
Hami 5.7
Alright so I finished up my Zone 6in lift today and thought is post the progression of my build since I purchased the truck last October,
then I went with a motofab 3" level and 1.5 in rear
next came the 3" PA body lift with some 18 x 9.5 wheels and a old set of 35 x 12.5 tiers
20190420_105833.jpg and now my current set up with the zone 6in and federal corragia 37 x 12.5 r18
my last truck I ran a level and the 35s for some reason this truck has turned into an obsession I'm sure some can relate, I am running 3.21 gears with an 8 speed auto, and have found no real power loose, with the 37s I'm thinking of a few things to next possible color matching the tow mirrors, and adding and exhaust and cold air intake, definitely need to get my rack chromed out to match, let me know what you guys think I should do next
Ohio5pt7
Ohio
this is stockView attachment 169424
View attachment 169427 and now my current set up with the zone 6in and federal corragia 37 x 12.5 r18
View attachment 169429 View attachment 169430
Looks good I have the moto fab 3" 2" right now thinking of the 3" body lift. How was that install?
Sent from my SAMSUNG-SM-G891A using Tapatalk
Josh88
Josh88
Nh
Hami 5.7
Honestly it wasn't hard just sucked I guess, the hardest part was the bumper bracket
Puba08
Long Island
Looks great. Installing a 1.5 Zone body lift hopefully this weekend.
Quick_Shifter
IG: @ak_trucks_pa
TOTY Winner
ASTON,PA
AK Trucks Tuned 5.7
Looks Great!! Did you do the 3" or 5" Rear Coils. Post your Measurements on that Beast
@Josh88
Josh88
Josh88
Nh
Hami 5.7
Thanks guys measurement is front 31" from center of hub roughly to fender and rear is 30 1/2" 3inch rear
Quick_Shifter
IG: @ak_trucks_pa
TOTY Winner
ASTON,PA
AK Trucks Tuned 5.7
Measure to the ground only suspension companies want you to measure from the hub which is not accurate when the wheels are on #1 and #2 we like to calculate the tire size into the equation on this forum. Not saying you cant operate a tape measure but I have trained a lot of guys in my life that claim to be competent and proficient with tools and tape measures and that cant hold the thing straight or in the same spot.
Josh88
Josh88
Nh
Hami 5.7
Good to know rear 47.25 front 47.5 same on other side, hope that helps
Quick_Shifter
IG: @ak_trucks_pa
TOTY Winner
ASTON,PA
AK Trucks Tuned 5.7
You're up there. !!! I used to be at Front 46 1/8” Rear 46 7/8” on 35's
My 35's measure closer to 33 but I had the eibachs set to 3.5 with the zone 6" and 5" rear coils with a TGC 1.5" spacer on top of them. I did not have a body lift on mine.
Josh88
Josh88
Nh
Hami 5.7
Yeah I'm definitely pleased with it I wouldn't mind gaining probably another 2in some how, there is a fine line of looking good and just odd being to high above the tiers
Nick@GotExhaust
Supporting Vendor
SC
Great looking truck. Let us know if we can help add to the build in the future!
