ttthiel
- May 24, 2017
- 141
- 132
- Location
- Mid Michigan
- 2010, 2016
- 5.7, 5.7
I have no idea how to disable or bypass the airbags either. I think disconnecting the harness under the seat might disable them, but that might cause other unwanted issues. Perhaps try our engine/performance section and see what the tuners think about it, I’m sure the fellas doing drag racing and installing racing seats have dealt with the airbags.
For the traction control you might think investing in Hptuners, not only because you can disable the traction control with it but also because you can tune many other different things, fan settings, torque management, fueling, timing etc.
I’ve eliminated some TM from my tune and I haven’t have the need to disable my traction control in full. For traction control you can write a tune to disable it completely, or you can disable it on the fly and when you shut the engine off the feature reverts back to normal. You need a laptop with you every time you want to do it this way, or you can make TM less aggressive or not aggressive at all. I like mine in full until i choose to disable the traction control using the button.
Good luck.
Are you running hptuners? I currently have a bullydog and it is terrible. I planned to get a diablo trinity after i finish the suspension and a cage. I love the option the diablo offers but I will do my research on the hptuners. I think i am just going to pull the abs pump relay and run it like that for the weekend for now.
