From the Bulletproof site.
Yes, we offer a
BulletProof Locking Pin that you can use to lock your hitch to your vehicles receiver. It is also compatible with all of our accessories, so you can lock your dual ball or any BulletProof Accessory to the hitch.
If you order more than 1
Locking Pin we will make sure that they are all keyed alike. Each locking pin comes with 2 keys.
BulletProof Locking Pins are rated to the same weight rating of your BulletProof Hitch™. Most locking pins available are only rated for up to 10,000 pounds.
The BulletProof Stainless Steel Locking Pin is possibly the best solution for locking nearly any hitch to your vehicle receiver and for locking your dual ball to your hitch.
This locking pin is rated to the max capacity of the hitch
14,000 - 36,000lbs and offers peace of mind when leaving your vehicle unattended. The pin has a thick, lockable barrel (end-piece) that will prevent theft as well as provide a solid hold on your hitch.
The locking pin is made from stainless steel to provide maximum corrosion and rust protection. The length of the pin works with all 2", 2.5", & 3" hitch receivers. It can also be used to secure the dual ball or other BulletProof accessories into the hitch channel.
This top-of-the-line locking pin has a universal fit, which means that it is compatible with any vehicle on the market.
Note: This locking pin is not compatible with the
BulletProof Weight Distribution Adapter.
Order the BulletProof Locking Pin in packs of one, two, or three depending on your security needs. If ordering a two or three pack, we will make sure that they are keyed alike, meaning you can use 1 set of keys on your locking pins for convenience.
FEATURES
