Need Your Help!! 20x8 stock rim: 295/65r20... Too Wide???
AHarris
Madison, WI
2016 1500 Big Horn
5.7L HEMI
I've been tirelessly researching what size tire to go with on my 2016 1500 Big Horn. 3" lift, stock 20x8 rims. I was really wanting to go with the 295/65r20 (35.1" x 11.6") but was told tires will cup as they're too wide for the rim. Wife won't let me buy new wheels, so I'm stuck with fitting tires onto these current rims. Has anyone run a slightly wider tire (11-11.6") on an 8" wide rim??? I don't want to ruin brand new expensive tires. ;)
295/65 r20
-OR-
285/65 r20
-OR-
275/65 r20
Thank you in advance!!
Bravobravochona
California
Hello! My first interaction here, I have the same wheel and went for the 295/65R20 gladiator x comp, so far they feel great, lil noisy but normal nothing unbearable, I already took em to the desert, here's a few shots.
Dean2
Near Edmonton
Width of your new tire is only 11.6", so 1.8" wider on each side than the rim. That is well within tolerances.
White Lotus
Toronto
I recently put on nitto grapplers 295 65 20 on stick 20” rims… it rubs on the sway bar and the frame… will 2.5 level( putting it in soon) and or spacers 2” solve the issue?
White Lotus
Toronto
Some pics
olyelr
Kewadin MI
A level wont help at all, but the wheel spacers will cure the rubbing. However, rubbing there really dosnt cause any issues.
White Lotus
Toronto
I have the same size tires but they rub on the sway bar.. did you put a spacer? Any rub on the pinch weld on the front wheel well?!
olyelr
Kewadin MI
Which brand, tire is this?
Looking to put the same on my 2024 2500 4x4 but want a good AT tire that is a bit better on the road than in the mud?
Falken wildpeak at3w. Great all around tire. Wear very well, not noisy, great traction in the winter.
Corjclark
Pittsburgh
I wanted to throw my input out there with my 2017 sport night edition. Stock rims, 285/65/r20 wildpeak AT4W on Bilstein 5100 leveling kit (set a 2 inch). Very happy with the look, and zero rubbing issues even a full turn.
StateOfMind
Orange County CA
285/60r20 in my 20x8 stock wheels, sport lift. Nothing rubs. The 285/65r20 is the same width, and 5% of width taller. You'll be fine.
FYI many tire manufacturers have a recommended max tire width for rim width. Many big tire shops won't mount something wider for liability reasons. Independent shops will do most anything.
And for my 2 cents, Toyo pen country AT3.
olyelr
Kewadin MI
I've got the Cummins. Running high psi will yield premature center wear on an 8" rim with oversize tires a bit.
Running high psi will get premature wear on any tire/wheel combo. My power wagon is empty most of the time and not towing, so i run them fairly low (45ish front, 35 ish rear). When i tow or load up the back axle, i add air…then let it back out when unloaded.
