New cam problems
Thewests2009
Pa
Hello everyone I have a major problem had a lifter go bad on me changed cam all new lifters got truck back together got two codes misfire on 1 and 5 so I pulled cover of and on 1 3 and 5 I have no movement and intake side what could possibly be the problem I timed everything to the T before hand 2012 5.7 1500 please help
yoda
You may have not gotten the push rods in the correct position, missing the lifter with the push rod. Very easy to do
James OBrien
St. Louis
5.7 Hermi
When I rebuilt mine I was pretty meticulous, and thought I had everything perfect. When I went to crank the motor by hand to double check the valve train was working I had one side that just didn't seem to work. Had to pull the valvetrain off and completely re-did that side again and finally it started acting right. It sucks but I'd pull the covers off, pull the rocker arms, and re-verify each intake/exhaust pushrod is right, and re-install.
T
Thewests2009
Pa
Well it dawned on me this morning that with 1 3 and 5 just on intake side that lifters may have collapsed and not popped back out
