New truck, have some questions
Harleygtp
Harleygtp
Cummins 12v
1SilverBullet2
North Dakota
2014 Big Horn 8 speed
For input on a adjustable track bar, the skyjacker one I bought is great. I like it, so far nothing is wrong and the directions for setting it up is pretty good. If you don't want to do that I have a 5" track bar drop bracket I didn't use, it's a Zone one. Great looking truck man!
Harleygtp
Harleygtp
Cummins 12v
Thanks man! I'll let you know. Hopefully someone can take a look at those pictures and give me some insight on what I have, aND what I should do to improve on it
1SilverBullet2
North Dakota
I see stacked blocks....I'd get those replaced with either 5" or 7" blocks. Which ever lift height you go with. Those are a no no, stacked blocks that is. Drop pitman arm for the steering box as well.
Johnn123
Ontario
That kit is screaming Rough Country at me but maybe its just me. Definitely need to address the rear lift at some point, depending how much you wheel the truck. If you dont leave it for the minute but I'd def look into swapping that block for an add a leaf. I would definitely look into an adjustable track bar as Lifted01 suggested. Again down the road though, you've got bigger things to address like getting the front end in working order, getting your new steering box in and removing the body lift.
Merc225hp
NA
truck
gas
I see 5" suspsion lift and 3" body lift. As posted sj DTBA27 track bar. You have a drop pitman arm already but only for 3"-5". As posted stacked blocks need to go.
Harleygtp
Harleygtp
Cummins 12v
Merc , you think I should get that adjustable track bar? Or are you saying it's installed on the truck already?
Harleygtp
Harleygtp
Cummins 12v
I'm learning something new every day!
Merc225hp
NA
truck
gas
Sorry for the confusion, yes the sj DTBA27 is a replacement for the **** ball and socket track bar you have now. Me yes i would say get one u will end up saving money in the long run.
Johnn123
Ontario
I Gotta agree with this...
Harleygtp
Harleygtp
Cummins 12v
I'd like to replace the bushings on the steering stabilizers , just to start. They look to be sway bar end link sized bushings. Anyone have any input?
ramburger
my input be ditch the dual set up
also ditch the swaybar not worth puttin money into and way overrated imho
Johnn123
Ontario
Ditch the stabilizers all together. They are absolutely useless and I still cannot understand why manufacturers waste cash on them.
Merc225hp
NA
truck
gas
As posted ditch the dual ss no need for them at all. When it comes to the sway bar try it without make your own choice if you need it or not.
Fryekenn
