BoatnerB
Had the oil changed in my 2025 Ram with the Hurricane SST engine. After following the instructions to reset the oil level (run engine 10 minutes then turn off for 5 minutes) 3 times the oil light and a low oil message stayed on. Arrg! Took to the dealer and learned the hack to reset the oil level:
1) Do not press the brake pedal and push the Start button. The “On” indicator will illuminate and engine will not start.
2) Wait 5 minutes (“On” indicator still illuminated)
3) Start engine.
4) Celebrate resetting the oil level.
Hope this helps someone avoid similar aggravation.
3) Start engine.
