P1416 code and I'm not sure what to do now
frankieochoa1979
Yakima, WA 98901, USA
Does 2006 1500 has been sitting and not driven for about 3 years, had a check engine light which was EGR valve replace that started the truck up ran just fine took her for a drive got about four blocks away real bad lifter tick code scanner said p1416 code cylinder 6 misfire, pulled plugs they were fouled so I replaced all 16 plugs swapped coil packs out, coil packs are good checked injectors swapped injectors out still same codes, pull the valve cover to find exhaust rod on cylinder 6 fell out not bent pulled the head off and cylinder six MDS solenoid with collapsed, replace all lifters and MDS solenoids start of the truck up ran like a champ took a four drive got a couple blocks away lifts are starts ticking again p1416 code cylinder 6 misfire I have no idea what to do now, The cylinder 6 exhaust lifter was collapsed but roller looked great so I don't believe the camshaft is damaged, I've cranked over the engine all the rocker arms rods everything look good flowing smoothly I just don't know what to do,I'm looking for some help, this truck has been a nightmare trying to fix
HarryS
Air Force
Clovis NM
Lifters and MDS work off oil pressure. I'd start there.
