RodRamCar
- Jul 7, 2022
- 338
- 449
- Location
- IdaHO
- 2022 Longhorn
- 5.7 4x4 w/ 3.92s
To put it simply, this is by far the easiest but most valuable part not to neglect. If you are over 100k miles, and you're not sure if your pcv valve has ever been replaced, replace it. Even if you're at 30k, pull it out give it a shake and listen for it to make a clacking noise as you shake it. If it makes no noise, replace it immediately. It's gummed up and won't allow pressure to ventilate leading to potential blown seals or blown motor. Go to Amazon below and order this. It's the Mopar identical part even with a Chrysler pentastar logo on it. $35
Standard Motor Products V470 PCV Valve https://a.co/d/6cSzai9
