theclassic
Add any negative or positive effects. MDS, ect.... If anyone is wondering, I know very little about oil.
There are two considerations on the protection of metal in the terms of coefficient of friction, viscosity or additives. Now, thanks to the API all over the counter oils have moves close to each other as they regulate oils in api starburst oils. So if you use an api oil, the only move to get more protection is to move up in viscosity. Now, you have an oil pump, which is an equalizer, as in either way the argument on either side of the 20 or 30 weight would be a small point.I’m glad to see this poll because I’m a tad confused
My new-to-me 2019 hemi Classic is due for an oil change
I’ve been using Royal Purple for a few years and have a bunch of 5w20 and 5w30 in the garage. I’m not sure which way to go, though I’m leaning toward the 5w30. I’ll be using a Royal purple filter.
My son lost the cam and lifters in his 2016 Hemi at 124,000 miles. He always had the dealer change oil and they used 5w20 conventional bulk oil.
So, I’m thinking that synthetic 5w30 may be a better choice…am I wrong??
There is a scientific way to prove it, you need to do uoa's and find out for yourself, see what wears more 20 or 30 weight oil, or see if they are close to the same. Every engine is different, looking at what happened in some other guys engine wont be helpful. If you know what to look for you can see if there are conditions in an engine that is being hard on oil, usually noted by the shedding of viscosity and/or heavier wear then normal. If you don't want to do all that, just run what you feel like running, what your gut tells you.
The other consideration is going outside the api and using a high additive oil to protect the metal, there are a couple threads that deals with this strategy thread 1 and thread 2.
At the risk of upsetting ram members who dislike facts, here is the consideration from an engineer who builds engines. I'll just have to risk more flogging from guys who hate oil threads in order to give this information to newer members, sorry about that. About 40%-45% of the forum uses 30 weight with no issue, seams like everyone else runs manu recommendation, a very few run 40 weight or higher. If you live in cold spot, it really pays to run 0w30 if your choice is 30 weights, but 0w20 is only marginally better in the cold then 5w20, and in many cases it is literally the same exact oil they just label differently. peace
I would say so, Does the 6.4l take a different oil thats recommended by the manufacture? The oil recommended for the 5.7l is 5w20@Burla - you want only 5.7L Hemi responses, correct?
Yes. 0W-40I would say so, Does the 6.4l take a different oil thats recommended by the manufacture? The oil recommended for the 5.7l is 5w20
So the viscosidad decreases as the temperatura increases...I think I got it!0w20 pennzoil 5w20 pennzoil
same pour point - same operating viscosity- as you can see the two are so close there is literally minute difference in cold performance, even less difference in warm performance. if I can I will find one that is literally just relabeled, it is 100% legal and can happen if the 5w20 has base oils that allows it to get the cold performance range of 0w20.
The bottom line is actually two lines, 0w20 and 5w20.
Yeah I don't know the differences between the motors. So lets keep just for the 5.7l. thanks thoughYes. 0W-40
Thanks for the post and presenting your experience.My 2011 had always had synthetic 5w-30 every 5k or so and at 143k miles two lifter ate through the cam lobes. When I got past 120k I thought all the talk of Hemi failure was because people were not maintaining their vehicles...wrong! I have built engines for 30 years and found what the machinist found. The surface of every ramp on the cam showed a lifting of the polish/plating with two lifter eating through. I thought the exact thing the engine builder did, namely stiction in the oil. The film strength of the oil needs to be higher in my engine. So after rebuilding the top end I now run 15w-40 synthetic in summer and 5w-30 in winter.
