Hello all,
So I originally thought the truck could have a bad fuel pump but there are no problems at start up and it idles fine after starting up. When I am in neutral and rev the motor to about 2500 rpm it initially gets there, but then the rpm's start to taper back down while still holding the throttle constant. If you suddenly take your foot completely off the gas when doing this, the truck will stall out.
Could this be a bad TPS or IAC motor??
Or dirty throttle body??
Thank You
Thank You
