Quick question for those that installed their Bilsteins themselves.
rexdog
US
I used the first one. I was a bit nervous about using it but it went fine. It seems like the safety clips wouldn't fit but it didn't end up being a big deal. Just go slow and alternate from side to side often.
AFMoulton
Nuevo Mexico
I rented one from autozone, free as long as you return it. Makes you nervous as **** to compress it and take it off.
I recommend a 1/2” drive impact to compress them. As we ruined a smaller one doing it.
2018 2500 6.4 4x4 4.10 Amsoil SS 0w-40, Softopper
Black Rhino Armory 18x9 +12mm
Cooper St MAXX LT295/70R18
2016 Durango 5.7 AWD 3.07 Amsoil SS 5W-30
1996 Nissan Altima 2.4 Amsoil SS 5W-30
Reactions: JB1
Moparfanatic21
U.S. Marine Vet - 0321, Now a Doctor...of Vehicles
I use these two compressors called my arms although most people call them .50s :D I don't have the ones with the safety pin I just go slow and if I hear anything I don't like I run like hell and throw the girlfriend on the springs...
quietpeen
2021 TRX
Hellcat
I used the first ones also. If they are on the spring properly and you don’t tighten or loosen one side too much there is no worry
mike19950
Delaware
I used the first ones too. I used hand tools only and kept oil on the threads so they wouldn't gall.
JB1
Houston, Texas
^^thats a nice tool, wonder what brand that is.
FlaSeadude
Washington, D.C. / Florida
I bought the same ones. I had previously swapped out springs on my Mustang Cobra with no issues. But the RAM springs are a lot beefier and I was concerned that the compressors might not be up to the task...
5isalive
Iowa
I tried to use the second type from hf but it didn't go well. I ended up going with two of the first types and put all four on each spring to make it even safer. 37cd66e6a179b06504a2f18c188b224d.jpg
Sent from my VS988 using Tapatalk
ram1500rsm
Trabuco Canyon, CA
What was the problem was it too big ? or not enough clamping power to compress the spring?
5isalive
Iowa
Those bars are supposed to be straight. They were bending and twisting that almost caused the spring to slip out. I couldn't get it to compress enough to install the new shocks at the highest setting.
Bassin12
Just had dealership reinstall my Bilstiens 5100 because they put washer in wrong place, managed to figure out what size top lock nut is it’s a M12x1.5 , used zinc grade 8.8, think this nut grade is suitable
