Guys,
My 2014 Dodge ram 1500 sport battery totally died today morning. First i gave a power boost and it lasted me for 3 weeks. Again it happened last night & i again power boosted and worked fine, but today morning it died again. Am sure is the battery.
Do you guys suggest any good place to buy battery in Calgary? Any specifications? What size rachet and socket do i need to replace the battery?
Sorry am not a handy guy and just learning. Appreciate your time guys.
L
Most batteries today are made by 1 of like 3 companies... No mattter the name. You can't ever go wrong - Interstate, Diehard (Sears), NAPA, Everlast, AC Delco (OEM)...
I'm not sure about brands in Canada... Always find a brand that'll support you when traveling. Meaning, if you are on a road trip, more recognized brands / store is best. Next, ensure they sell the same or higher Cold Cranking Amps (CCA). That's how much power is there to start the truck. Ensure the battery is the same size, with top or side mounted connection. Larger is good, but it must fit with hold downs in your truck. Buy the best you can afford!
For the US we can goto most auto parts stores, they'll test your battery and alternator for free. Walmart can do this, even if they don't stock your batt.
Batteries will die quickly in extreme heat, like me in Texas. Now the cold or quick cold temp change will drain a battery. Your battery died now probably cause you've hit the first cold snap in your area. Batteries that are just holding on, will give up - - either at the first hard cold snap - - or the first extreme heat increase.
Your can change the battery yourself, just takes a few tools. Many in this post have given you great advice. Just remember, disconnect the Positive (+) terminal first - - then the Ground (-). For installation, connect the Ground (-) first, then the positive. This ensures you have a ground so the angry pixies (electricity) have a place to go if you touch the Positive to any metal.
BTW, when making connections, don't let any tools touch metal... It will spark on you.
I hope this helps!
