Ram7081
- Joined
- Sep 9, 2015
- Posts
- 473
- Reaction score
- 173
- Ram Year
- 2025
- Engine
- Hurricane 3.0
Deleted
anyone have a link for the tj rear 3/4 spacer? been trying to find somthing for a couple weeks
and these go on top or bottom of the spring. i will order tn, awesome
Welcome.I'll be ordering the RE ones as well thanks guys!
Sorry to revive an old thread. Seems to be the only info on the web for using TJ spacers in the rear. I picked up a set today and I'm going to install soon, did any of you running a TJ spacer have any issues?
I have not seen either issue in any I have installed. They all went on perfectly even the 1.5" spacer
1.5 is the same style as the the 3/4 just the bottom naturally is 3/4" taller, Your spring has nothing holding it in place so if your shocks are long enough for the spring to unseat when the axle droops it will be the top of the spring that should become unseated thanks to gravity .1.5" poly? good to know, my concern was if the poly would keep the spring centered long term under HD use. The 3/4" Jeep spacer is open, there is only a small lip to center the spring. I would assume the 1.5" poly spacer maybe is made different?
