remote start ebay link
ricci427
CT
Hey guys,
I've looked at old threads for remote start, but a lot of the ebay links seem older, I got put onto the link below, just wondering if anyone has used this particular kit, and if there were any problems.
https://www.ebay.com/itm/232580829892
Cstan
Rome, Ga
I used the Fortin evo kit on the 09I used to have without any issues at all and it is a little cheaper than the one in the link you provided.
Jimmy07
Hey guys,
That kit is perfect and simple to install. Comes with the data link cable so you can do the second flash yourself without sending it back. It’s compatible with this https://www.ebay.com/p/Compustar-Dr...8%26rvr_ts%3D0d84475b1670ad4d8ac33015ffeeef42 if you want to be able to start from anywhere with your phone.
Jimmy07
Yes, I have it along with the iDataStart (same as flashlogic). The cellular plan for drone is $65/year. If you want it to gps your truck, it’s a little more, but I personally don’t care about that.
ricci427
ricci427
CT
On remote start, I installed all working fine, I did notice some wiring for the horn, that wasn't a required install, it was listed as optional.
Curios as to if this wiring for horn, would stop the horn from sounding 3 times when activating auto start, anyone know if this is the case?
Greg Oetker
USA
I don't think it will stop the horn from honking since that is controlled by the truck itself. You can go into the radio settings and turn off the horn when clicking the remote.
JohnnyMac
SouthWest Washington
2018 1500 Laramie / 2024 3500 MegaCab Laramie
3.0 EcoBurner / 6.7 Cummins HO
^^^ What he said ^^^ I did exactly what you want to do. Didn't hook up the horn wire, and turned it off in the truck's settings.
ricci427
ricci427
CT
Thanks to both for advice on that, had no idea I could do it through settings that are in the radio. Sure my neighbours will be happier now as I start truck around 5:45am M-F.
