Replacing headlight help
firemanjay
2015 1500 sport, pass side lowbeam out, replaced with a new one but lamp won't come on, all other lights work, what am i missing
NJMOPAR
Older and faster
ELizabeth, NJ
Jiggle the connector to the housing.
If the light flickers on/off it's likely a loose pin inside the connector. Check them all for looseness/corrosion.
firemanjay
firemanjay
Thanks, that was the problem. Tightened the pins and everything is good to go, ended up doing the Hikari 9012 bulbs and the canbus adapter.
Did notice with their adapter you can put the connection on backwards but i figured it out
Thanks for the help
firemanjay
firemanjay
Yes it is, now have to wait till dark to test them and adjust if needed
firemanjay
firemanjay
Will more than likely order the 9005 for fogs and high beam
Will the Hikari fit for the high beam?
Looked real tight in there
