RPM Fluctuation
Ryan Cruz
Rio Grande Valley, Tx
hello guys i'm having some rpm fluctuation at idle, I've noticed it doesn't do it all the time, it comes and goes. I took it to a shop to check the computer and everything came out good. No codes were found. I was wondering if any of you guys had experienced something similar. any info would be greatly appreciated. thank you
p.s. I have a 2013 5.7 Ram
cwendel
US
Cummins 6.7
If it is tuned, could be the tune has issues with colder temps.
2013 2500 6.7 cummins crew cab. white and stock as can be
using Tapatalk
Bigskyroadglide
Moderator
Member Relations Specialist
Moderator Supporting Member
Montana, officially RETIRED
Hemi 5.7, supercharged
Check your intake bolts, mine did that and two were loose caused a vacuum leak.
Don't over tighten, I think torque specs is like 84 INCH lbs or something like that. In some sequence.
R
Ryan Cruz
i already cleaned the throttle body, I'll look into the injectors next. thanx hopefully that will be it.
1SloRam
Ms
Having the same issues. Was told intake manifold gaskets need replaced, causing vacuum leak. Already cleaned TB and did relearn, didn’t help. Truck is tuned, but tune isn’t issue.
Allen zhu
Cn
Ryan, is your truck ok? I have the same issues
JohnnyMac
SouthWest Washington
2018 1500 Laramie / 2024 3500 MegaCab Laramie
3.0 EcoBurner / 6.7 Cummins HO
I know this is kinda basic, but if the defroster is on, the AC clutch will cycle on/off and affect the RPM's. Just a thought....
Allen zhu
Cn
Mine only happens when idling, the rpm will fluctuate, and even engine dead once or twice.but the rpm is very stable when the d gear is engaged.
