Should you replace rotors with every break job
APPsBeast
California
Approaching 40k miles and I suppose I should consider changing the pads, I’ve heard mixed opinions saying resurfacing isn’t ideal and you should just replace to Rotors and start from scratch with a fresh set of pads, what would you do?
GRN69CHV
Pennsylvania
There's really no way to measure run out without a brake lathe. In the old days, we would pull the calipers, replace the pads and move on. Today, in the big scheme of things, cost of rotors is insignificant. Mine were done at 55K, 58K (frt/rr) respective.
Nick@GotExhaust
Supporting Vendor
SC
GsRAM
2017 Dodge Ram 2500
Hemi, 6.4L
I personally would not if they are not grooved, not warped and above minimum thickness. Clean/deglaze them with some sandpaper (both sides) install the new pads and move on. But if you want to spend an extra $100 anyway, go ahead. Up to the installer really....
Villalobos
USA
5.7l hemi
I diy brakes. Last several years I’ve used Detroit Axle brand. Has worked fine on my vehicles. Pads and rotors all around less than $200 for most vehicles. At that price I change pads and rotors all around and I change them often.
HDGoose
L6 Diesel HO
My brakes on my 2013 RAM 2500 diesel were within specs at 125k. Had I not traded in the truck, I would have done a brake joball around. I pulled a 12k 5th wheel trailer 30% of the time and the brakes were still very good.
joelmic
stl mo
2022 Ram 1500 Big Horn 4dr Quad Cab 4WD SB
What is the Rotor thickness SPEC???
I'm in the exact same boat and was just gonna change pads... I'm @ 35K
No Tyme
Bryan, Ohio
If they are not warped or grooved I would say no. I have installed just front pads on several cars and trucks over the years with no issues.
tron67j
Maryland
My vote, replace. Front rotors and brakes do most of the work in slowing and stopping the vehicle and since they interact with each other it makes sense to have all parts replaced at same time. You may not feel anything now, but new pads could exacerbate an issue where there is build up on the rotors, which causes the pulsation that is commonly, but incorrectly, referred to as warped rotors (rotors don't actually warp). Good luck.
Nick14
Knoxville, TN
Whenever I replace pads, I take the rotors off and have them resurfaced. There is a minimum thickness spec. on the rotor. The shop will tell you if they can make a cut or not. Nick
canadiankodiak700
Northern Ontario, Canada
3.7L Pentastar
Rotors don't warp? Roflmao
If only you could see the ones from my old 98 neon after Street racing. Multipal heat cycles where they glowed Cherry Red at night and to the point where they would barely stop the car. When they come off at the shop, there was noticable warpage.... No build up.
Same on the front of my ranger after hard braking down a mountain trail then crossing a creek at the bottom, severe vibration after that, rotors were warped.
tron67j
Maryland
Well, I don't know your set up, but your experience is not relevant to this discussion. I think it is reasonable to expect our discussion about normal use within tolerance levels for the materials on the vehicles we are discussing will not be relevant to street racing, and vice versa. Any material that is exposed to extremes past design will react differently and of course in that case you might have something warp. I didn't think I would have to first preface my statement with a qualifier that my statement does not apply to Neons used for street racing. And before anyone else raises an issue about modified rotors or use beyond the manufacturer limits of trucks, please accept my apologies in advance that your use is also not coverd by my statement.
62Blazer
Midwest
I've replaced brakes on many cars over the last 20 years and only replace rotors maybe 25% of the time. Typically if they are not grooved, warped, or getting really crusty I just scuff them lightly with sandpaper and spray them down with brake clean. Back in the day if the rotors were grooved or warped you had them turned but nowadays it's usually easier and just as cheap to buy new rotors. Rotors should be stamped with the minimum thickness on them. I've never seen a brake rotor that is below minimum thickness unless it has previously been turned, or the grooving or warping is bad enough where by the time you turn them they are below spec.
bm02tj
B C Canada
Check for cracks and warpage if good light sand and reuse as it will be better than new ones
If one needs replacing change both on axle
Burla
2010 Hemi Reg Cab 4x4
Rotors are so cheap I say yes, and keep the old ones. Some day your kids will be smelting them for good use.
Tach_tech
5.7L HEMI
At my shop we machine rotors with every pad change as long as there is enough meat left, if not, we replace them. It’s usually only an extra 1/2hr labour or so. You’re not buying new rotors for 1/2hr of labour.
I’ve seen far to many issues come from just doing a pad slap so we never do that. You wanna do that on your own, it’s fine. From a shop point of view it’s not worth the risk of a customer coming back with an issue.
