Spark Plugs
Aussie-John
Australia
Hemi V8
Hey all.
So I have a 2018 5.7 Laramie down in Australia and I’ve just been quoted $120 each for new spark plugs plus labour, and apparently there are 16 of them.
Is there any other comparable plugs? Seems a lot of money for spark plugs.
Cheers
J
46RamMan
U.S. Navy Veteran
Missouri
Hey all.
Cheers
J
Advanced Auto sells
Hey all.
Cheers
J
Advanced Auto sells Autolight Iridium Plugs for your Ram for $8.89 each so I think they are funning you on that price and yes there are 16 of them.. Have a great summer down under... and they are great replacement plugs for your Ram
Aussie-John
Aussie-John
Australia
Hemi V8
Thanks man.
Do you have a part number or the like??
46RamMan
U.S. Navy Veteran
Missouri
Thanks man.
Yep the Part # from Advanced Auto is XP5325 . Hope this helps.
Exact Fit
for your
2018 Ram 1500 Laramie
Iridium Spark Plug; OE Style; Iridium Enhanced Center Electrode. Proprietary V-trimmed Platinum side wire. 0.6mm finewire design.; Requires 2 Plugs Per Cylinder; .045"/1.1mm; 16 Req.​
Congrats, it is hard to surprise me anymore with the garbage we see around here, like $1200 transmission fluid swaps, but you did it, lol.
120 x 16 = 1920 plus labor for a spark plug change? Are you sure they didnt mean 120 for all the plugs plus labor? In the states, I think the going rate for hemi plug swap is 4-5 hundred all in.
You might want to pick one cylinder with easy access, and just pull them and see the condition, pull both plugs on that cylinder and see if there is notable corrosion on either pug. I would at a minimum check if it is needed before spending any kind of money you are suggesting. You have the updated plugs, so they are the longest lasting plugs around.
EdGs
FL
Aren’t those iridium plugs supposedly good for 100,000mls?
Thought I read/heard that somewhere on here
Yes, 100k miles for the plugs.
NGK 92145 is the OE replacement for these, IIRC
When I changed them in my '15 at 106k miles, the originals were worn very little.
EdGs
FL
When I checked with the dealer for plugs for my '15, they quoted me $24 plus change each, so would've been out almost $400 just for plugs.
I got 16 of the NGK 92145 from RockAuto for right around $100 plus shipping.
Also bought the GearWrench 80546 magnetic spark plug swivel socket from amazon for $15, and it was worth it's weight in gold.
Took me about 2 - 3 hrs. and a couple beers and I saved $300 on the cost of plugs and at least 2 hrs. of labor.
Aussie-John
Aussie-John
Australia
Hemi V8
Exact Fit
for your
So I tried to order these from one of our suppliers over here who states "They will not fit a 2018 Laramie"
Can you confirm that they will 100% fit?
See below
DILLIGAF
Canadian Forces
Canada
I buy the cheap champion coppers and change them out every 2 years.
crackerjack1957
2014 Sport 1500 CC 4x4
Hemi 5.7...65RFE...4.56
Take your pick in the Iridium section.........all these work......most use NGK92145
Screenshot 2021-12-01 at 08-20-05 2014 RAM 1500 5 7L V8 Spark Plug RockAuto.png
BadHemi2014
Greater Cincinnati area
Take your pick in the Iridium section.........all these work......most use NGK4469
Like he said, altho I would say most use the NGK 92145, that's what i have in my 2014. And definitely get that GearWrench 80546 it is a lifesaver!
crackerjack1957
Thanks for catching the wrong number.......I corrected
Aussie-John
Aussie-John
Australia
Hemi V8
WOW We get stung over hear. Those NGK 92145 are over $20 a plug here.
Thanks for all your help guys.
Treburkulosis
Glorified Car Washer
Haslet, TX
I am also running the NGK plugs. Have you tried Rockauto? Not sure if they deliver to you in Australia?
rockauto
plugs for 2018 Ram HEMI
international shipping
EdGs
FL
If RockAuto will ship overseas, go for it!
Even with the exchange rate, the NGK 92145 will still be around $9 each, and I can't imagine that overseas shipping will run you more than $100.
You have nothing to lose by checking it out.
Don't forget that GearWrench 80546 tool from amazon, worth it's weight in gold.
Btw, here's a thread about original plugs at 200k+ miles, they look surprisingly great even at that high mileage.
Best of luck to you with getting a good deal on the parts you need, and getting the job done.
WireEd
Syracuse, NY
Hey all.
Cheers
J
Wow for that price it should include a spare engine!!
aimcgma
