Walt2137
I use Mobile 1 and have for years.
Walt
Walt
Mobile 1 is tough to beat imo as it is a GREAT oil , but Redline and PUP is much better imo .I use Mobile 1 and have for years.
Walt
I believe 20wt PUP has about 60ppm of Molybdenum ....imo that's about 450 ppm too little ( for a 5.7L Hemi ). That's a great price on that oil.How much molly has the PUP?
Pennzoil 550045202 Ultra Platinum 5 quart 5W-20 Full Synthetic Motor Oil (SN/GF-5 jug)
Found 5 gal at $25 and wanted to use it for 2015 1500 5.7l , have 25000 miles.
Thanks
Just me , I wouldn't run any 20 wt in mine even if it was free .
Thanks for your reply!
I have searched every where to find some info about this oils when it comes to Molybdenum with no luck, wanted to compare some oils. I see that lot of folks here like the
Redline 5w-30 motor oil with Royal Purple oil filter, as i guess may have more molybdenum than PUP.
Now may just use PUP 5w-20 with Mopar oil filter just to stay within their warranty policy, but maybe for sure that Redline w/RP Filter 5w-30 maybe better.
Even if switch to Redline 5w-30 is that any good for California weather? here is quite hot days...
Thanks!
We all know you're just a radical at heart Burla. LolSo any issue that is a warranty thing would be dependent on the oil in the sump at the time you take it too the dealer, hint. If you are that worried you can always change your oil before a warranty item if it happens, and do the cancel order trick with receipts to prove oil changes. Personally I just don't give a **** so I ran what I wanted too, I guess somehow that is radical. Either that or run what they want you to, this forum's most popular oil strategy is to run 5w20 and Pennzoil is the most popular synthetic oil. I would run 5w30 PUP or Redline and a RP filter, if they denied me and I lost in court I would sit outside the dealer with a gun and wait for the mother fkers to get off work. Whew glad I am out of warranty![]()
Ok gentleman, If you have the Max Lifetime warranty you are Not allowed to use an aftermarket Oil Filter, or a filter with the wrong part number like the SRT oil filter. If you have an engine failure related to oil FCA can deny the warranty work if there is an aftermarket oil filter on the engine. This is per Max Lifetime warranty representative. Basically all they need is an excuse.
I spoke with them about the oil, and oil weight recommended by the manufacturer must be maintained for the Lifetime Max Warranty. Keep in mind the Manufacturer warrany and the Lifetime Max warranty are two different things; under different legal entities. The Lifetime Max warrenty starts after the manufacturer warranty ends. For me in the 2500 with the 6.4 I have only two oils to choose from, good thing is both are fantastic. But the Mopar paper oil filter I'm not happy with. Hopefully I can get something official to clear things up.What about using a different weight oil?
