Synthetic Motor Oil Poll 2017
What Synthetic Oil(s) Do You Use Most Often?
  • Total voters
    1,290
Dean2
Near Edmonton
Never ceases to amaze me how much nonsense gets posted on oil threads.
Click on the link above to read the whole article, this is just the intro.
Pennzoil Vs Mobil 1: Head-To-Head Comparison​
Best Review, Blog, Comparison, Engine Oil / By Ryan McCain / November 6, 2025
Pennzoil Vs Mobil 1: which is better?
Pennzoil Ultra Platinum and Mobil 1 represent two different philosophies that both deliver excellent results.
Pennzoil Ultra Platinum uses a gas-to-liquid (GTL) synthetic base oil made from natural gas rather than crude oil. This manufacturing process gives it an edge in engine cleanliness and resistance to oxidation.
Mobil 1 prioritizes film strength, which means better protection during metal-to-metal contact under extreme loads. This is particularly important during cold starts and high-stress driving.
Let’s get right to it: Pennzoil typically wins on piston cleanliness and oxidative stability. Mobil 1 edges ahead on overall durability and fuel economy. Both oils easily handle extended drain intervals of 10,000 miles or more when used with appropriate oil filters, and both meet or exceed current API and ILSAC standards.
The decision essentially boils down to what matters most for your specific application. High-performance engines that see track time might benefit from Pennzoil’s cleaning properties. Daily drivers focused on longevity and fuel costs might lean toward Mobil 1.
This post gives you a head-to-head comparison between these oils based on engine protection, fuel economy, leak prevention, and price can help you choose the best-suited product for your need.
Pennzoil Vs Mobil 1: Product Line Comparison​
The main difference between these oils is how the base stock is manufactured. Pennzoil Platinum and Ultra Platinum use Gas-to-Liquid (GTL) technology. This GTL process produces a fully saturated base oil with essentially no sulfur or nitrogen. Shell, which owns Pennzoil, pioneered the large-scale use of GTL base stocks.
The key advantage is that GTL base oil doesn’t contain the Group III+ hydrocracked oils that most competitors blend with Group IV synthetics, which gives it a cleaner starting point.
Mobil 1 historically built its reputation on Group IV Polyalphaolefins (PAOs), which are chemically synthesized molecules. Modern Mobil 1 formulations blend Group III+ (hydrocracked) and Group IV (PAO) base stocks. For example, Mobil 1 Supercar 0W-40 uses a PAO-Ester blend (Group IV/V). However, newer API SP formulas like the 0W-40 European Car Formula have moved away from the traditional PAO-Ester blend entirely, with completely redesigned base oil and additive packages.
pennzoil-vs-mobil-1-product-line.jpgCompared to Pennzoil, Mobil 1 seems to have more diversity in the product line.
Pennzoil’s Product Range​
  • Pennzoil Ultra Platinum (full synthetic made with natural gas, top-tier)
  • Pennzoil Platinum (full synthetic with advanced protection)
  • Pennzoil Platinum High Mileage (full synthetic for vehicles over 75,000 miles)
  • Pennzoil Platinum Euro (for European vehicles)
  • Pennzoil Full Synthetic
  • Pennzoil High Mileage Full Synthetic
  • Pennzoil Gold (synthetic blend)
  • Pennzoil High Mileage (conventional-based for vehicles over 75,000 miles)
  • Pennzoil Motor Oil (conventional base oil)
Mobil 1’s Product Range​
  • Mobil 1 Extended Performance (0W-20, 5W-20, 5W-30, 10W-30)
  • Mobil 1 Extended Performance High Mileage (0W-20, 5W-20, 5W-30)
  • Mobil 1 Hybrid (0W-20)
  • Mobil 1 Classic Car (10W-30)
  • Mobil 1 C40 GT 0W-40 (for Porsche GT engines)
  • Mobil 1 Turbo Diesel Truck (5W-40)
  • Mobil 1 Racing 4T (10W-40 for motorcycles)
  • Mobil 1 V-Twin (20W-50 for V-Twin engines)
  • Mobil Super Synthetic Euro (5W-40 for European spec vehicles)
Pennzoil Vs Mobil 1: Key Differences​
Pennzoil and Mobil 1 are two well-known motor oils that share some characteristics.
pennzoil-vs-mobil-1-comparison-table.jpg In terms of engine protection, changing intervals, and leak prevention, Mobil 1 has an advantage over the other Pennzoil. While Pennzoil oil is more cost-effective and efficient in terms of fuel efficiency.
HEMIMANN
Minneapolis, MN
2017 2500 Laramie Crew Cab
6.4L HEMI
When FIAT took over in 2009, it changed to Pennzoil Ultra Platinum because they are under the SOPUS umbrella that FIAT was aligned with. That is the only reason it changed. Nothing to do with quality, it was all a business decision based on alliances.
And Shell is a European Corporation (Royal Dutch Shell).
Biggfoot44
USA
I almost hate to ask .
After the completion of two changes of 5-30 Restore & Protect , will be needing to pick a " Normal use " oil . '17 5.7L MDS .
5-30 is a given .
Criteria includes off the shelf from mainstream store , close to me . Which leaves out PUP .
4 seasons , but not sub zero , and rarely 100 deg F . Complete spectrum of driving from stop & go to highway cruise control, but lots of weekly miles . 5K miles interval ( maybe 6 or 7 , but not 10k plus )
Leading Contenders seem to be Penzoil Platnum , and Valvoline Extended . Anything major stand out between them ? ( l've got information overload between here & Speed )
Burla
2010 Hemi Reg Cab 4x4
I'm running Valvoline extended in everything except my truck that needs it's honey. I would be changing oil at 5k miles if you are on the shelf oils, as you can see at 7k miles it is low tbn. over 300ppm moly on uoa.
HEMIMANN
Minneapolis, MN
6.4L HEMI
Again, Hemi is a special case engine due to the poor oiling system. I would only use an oil with heavy moly additive.
That pretty much defeats your criteria of off-the-shelf oils. If you want your engine to last, that's what is needed. I won't recommend and off-the-shelf for a Hemi. After years of this Forum you'd understand why.
Motoman501
Sparks, NV
I'd continue with the R&P for off the shelf. It is putting up some impressive UOA's for wear as well as the cleaning abilities. No reason you can't continue to run it especially with 5,000 mile OCIs.......
Mobil 1 ESP 0w-30 is also impressive however doesn't have as much moly as R&P.
