"Tesla Style" 10.4 Android Radio Information
Maligator
Hem 5.7
So, I don't know if this has already been discussed, but there is a Russian forum where they have dissected these and made them highly customizable. If you're interested, go to the following link and let Google translate the forum.
https://4pda.ru/forum/index.php?showtopic=877711
I've got mine looking much better, the next step is root access to begin changing the system apps.
Looks good man, glad you are having some luck with yours!
dearchristopher
Galveston, TX
man I want to try one of these so bad. but I don’t want to risk my AC not working, or losing my factory backup cam.
SitKneelBend
St. Louis
3.6 Pentastar
More improvement (subjectively). The Russian developers have modified the system apps to have a more appealing look with a black high contrast background. I needed to root with KingRoot in order to make these changes.
My navigation is now voiced by Arnold Schwarzenegger!
34c643729fd0cc2d0c3934411c28274f.jpg10cb3990d5c5783c9d89ff30e2b15668.jpgbec4e75b745f2cce6f79da5f226f506f.jpg
Wayne Stella
Goose Creek
I ordered my 7.1.1 from Phoenix and they sent the wrong one the first time. A month later I finally get the right one this past Saturday. It takes longer to figure out what wires go where since there are no instructions or wiring diagrams. In fact not a single piece of paper. Got what I thought was the correct wiring connected and everything works great except........the factory backup camera. In reverse the screen changes and says no signal. I figure I just connected the yellow RCA plug to the wrong plug behind the radio. Take the dash apart and switch the plugs around and still no signal. The factory camera does work since you could see it when you use the AUX button on the radio. I guess that's where I had it connected the first time. Anyway another problem came up where the touch screen went dark and no longer works.......sometimes. This morning I started the truck and the touchscreen came on but as soon as I touched it to change a setting it went dark. It is a good thing the radio starts back up where it left off so I can have AC since its only a million degrees here in SC. I had messages in to Phoenix and they called me late Monday night. We did a video call (I like they will do that) but I still had the dash together. Was supposed to get a call last night but no dice. I'll call them later today. Anybody got any idea why the screen went dark and then comes on sometimes but locks up and touchscreen doesn't work? I'm thinking maybe a loose wire in one of the harnesses they supplied. Also, the headlights are always on if you leave it in the AUTO mode. I saw another thread that mentioned that issue after installing an aftermarket radio. No mention of the radio type though.
SitKneelBend
St. Louis
3.6 Pentastar
That was me with the auto headlights staying on and it's this radio. Are you able to navigate to any settings or does the screen blank as soon as you touch it?
Wayne Stella
Goose Creek
I did a hard reset of the radio an hour ago with the RST button and everything seemed to work after the reboot, except the headlights staying on, for a few minutes and then the screen went dark. I'm like WTF? I'm thinking I'll go out there in a while and it'll start back up again and stay on for a few minutes so I'll think I'm good and then............****
SitKneelBend
St. Louis
3.6 Pentastar
Make note of the power button location at the top of the screen while it's on. Next time the screen goes out, press the location on the screen where the power button would be to see if it brings it back. It moves around bssed on the selected theme, but here is mine in the top left of the screen...9c096d441a46f98766161c77d14a6cfa.jpg
Wayne Stella
Goose Creek
Started the truck during lunch and yes the radio came back on. It stayed on for about three minutes and then went dark. My power button is still in the middle and it will not restart the radio. Really strange. A wire coming loose after the truck runs for a few min? Something heating up and turning off the power? I'm going to take it out after work and manually power it up and see what happens, I guess. Does this thing have a screen timeout setting ?
SitKneelBend
St. Louis
3.6 Pentastar
I'm very interested in your head isn't issue so if Phoenix answers that question I'd be grateful if you could post what they say.
Here are all of the available settings. I haven't put it in a friendlier format yet. It's been translated from Russian so some of the English might be strange but it's better than the Chinese description settings alone.
Value
System
The sound of a key - TOUCH TONE: (ON/OFF) def: ON
Sound when you tap the screen
Start navigation-AUTO RUN NAV: (on / OFF) def: OFF
The AutoPlay navigation
The Chinese program of navigation
Built in Navi-LOCAL NAV: (on / OFF) def: OFF
Reverse path-Parking Guideline: (ON/OFF) def: ON
Parking lines
Display side video RIGHT CAMERA: (ON/OFF) def: OFF
Recognition of road signs on the starboard side
Recognition of road signs ahead
Front video display-Front Camera: (on / OFF) def: OFF
Module DRV - DVR MODE: (TOUCH/BUTTON) def: TOUCH
DVR control type
The speedometer on the screen of the launcher
Show hour speed - Show Speed: (on / OFF) def: on
Crash sound-Warn Sound: (on / OFF) def: on
Warning signal on the state of the car (MCU)
Sound when reversing (MCU)
Reverse Mute: (Sound Off/Sound On) def: Sound Off
Setting the blank screen-Black Setting: (Black LCD/Stand by) def. Black LCD
Action for the screen off button
Camera display type W/x (MCU)
Reverse gear type-Camera: (Aftermarket/Factory) def: Aftermarket
Display the temperature at the top. blind
Temperature display - shows Temp: (ON/OFF) def: OFF
Recovery launcher Wallpaper
Reset Wallpaper - Reset Bg: (on / OFF) def: ON
Select the TV module, the TV Select: (TOUCH/BUTTON) def: TOUCH
TV control type
DOP. control the brightness and contrast.
Color settings - color Set: (ON/OFF) def: OFF
Trace line reverse - Parking guideline: (NEW LINE/OLD LINE) def: NEW LINE display Style Parking lines
Unit System: (Metric/US) def: a Metric
System of units
The volume of navigation - NAV VOLUME: (35)
The volume of the navigation
Advanced
Value
Advanced
The choice of the type - CarTypeSel: (MondeoZhishengl))
The choice of a car:
Built in Navi-LOCALNAV: (Serial Num:) (Navi Active:)
Built-in navigation programs (for China)
Select TV...- TV Select: (Dehui TV Moduel / Xinfa TV Moduel) def: Dehui
Type of TV module
Reverse Mute: (Sound Of/Sound On) def-Sound On
Non-standard height of the car (MCU)
Single block machine - (ON/OFF) def: OFF
ISU speakers (MCU)
Speaker Type: (Small Speaker/Big Speaker) def: Big Speaker
Hybrid: (ON/OFF) def: OFF
Hybrid engine (Camry)
360 camera: (on/OFF) def: OFF
Circular view camera (MCU)
The right wheel
Right peptide: (ON/OFF) def: OFF
Management of reverse-side MCU (the MCU)
Reverse from OBD: (on / OFF) def: ON
Plugin Radar: (ON/OFF) def: OFF
Parktronic
OTG_USB1.1: (ON/OFF) def: OFF
USB V1 mode.1
USB HOST USB V1 mode.1
HOST_USB1.1:(ON/OFF)def:0FF
USB. DVR: (ON/OFF) def: OFF
USB video recorder
Show Logo: (on / OFF] def-OFF
Show Logo on boot
RsightText: (on / OFF) def: on
Changing the caption for the right camera
Lighting control on the MCU side (MCU)
Light Soft Control: (on / OFF) def: OFF
Changing the right channel for the camera
Switch Right Channel: (on / OFF) def: OFF
Install the seat heating: (ON/OFF] def: OFF
Seat heating (MSS))
SHOW APP - (ON / of)) def: on
Hiding some apps in the top curtain (Land Cruiser only)
New Air: (ON/OFF) def: OFF
New climate panel (only CS5, LieBao CS9)
Change to go: (ON/OFF) def: OFF
Logo change (Infiniti QX50 only)
Show bottom air: (ON/OFF) def: on
Climate control display in the bottom bar
Up and down settings: (positive/negative) def: positive
Swap the functions of the up and down buttons (Camry)
Show 360 Car: (on / OFF) def-OFF
Allow the display chamber of the circular review
Display circular camera motion in the z/x __
USB 360: (on / OFF) def-OFF
Mute (MCU)
Sound Attenuation: (ON/OFF) def: OFF
8836: (ON/OFF) def: OFF
Can't Watch Video in Motion: (on / OFF) def: OFF
Cadillac car type: def.ATS
Def Camry Year: 2012/2013
K3 Year: def: 2015
LandCruise Year: def: 2016
H6 CarType: daft-Upgrades
Highlander Year: def: 15/16 Manual Air
REGAL Year: det:2006-2008)
WCarType: def: Magotan
Preventing video from being watched on the move
The choice of model cars Cadillac ATS. STS.XTS
You
Year selection of Camry machine
Choice of the year of the machine KZ
Choice of the year cars Land Cruiser
You
Choosing the type of machine N6
Choice of the year of the machine Highlander
Choice of the year of the car REGAL
Select the type of car Volkswagen __
MCU -> System
Power key set: (Any key/Power key) def: Power key
Wheel Setting: (LOW-Z/HI) def: HIS
ACC Volume: (No Save/Save) def Save
Reverse Mute: (Sound Off/Sound On) def-Sound Off
Tough Origin: (positive/negative) def: negative
Origin of Screen: (positive/negative) def: positive
TV Switch: (on / OFF) def: ON
Dimmer Type: (jun shao/gemei) def-jun shuo
Bit Depth: (8 bit/6 bit) def: 8bit
Google APP: (OFF/on) def: ON
Flash Logo: (on/OFF) def: OFF
DSP Sound:(ON/OFF)def:OFF
360 Camera: (on/OFF) def: OFF
Mar Type: (MXNavi/Careland/Map) def: MXNavi
Plugtn Radar: (ON/OFF) def: OFF
OTG USB1.1 (ON/OFF) def: OFF
USB HOST 1.11.(On / OFF def:OFF
Auto Antenna: (ON/OFF) def: OFF
Frequency: (Normal/IF/HF/LF) def. Normal
Radar Sound: (on / OFF) def: ON
Ford Lamp: (ON/OFF) def: OFF
Weaken Video: (on / OFF) def: OFF
Weak Right Video: (on / OFF) def. OFF
Displaying the menu of application program TPMS Ford
Ford TPMS: (ON/OFF) def: OFF
Serial port TPMS: [on / OFF] def: OFF
Display in the application menu of the UART TPMS program __
Power liftgate: (on / OFF) def: OFF
The trunk actuator (only for custom=5, and some cars)
Ford wheel up and down button need to control the volume: (on / OFF) def: ON Allow up and down buttons (only for Cadillac ATSL)
Ford wheel left and right button need to control the song: (on/OFF) def. ON
Allow left-right buttons (only for Cadillac ATSL)
The PWM frequency is 1.2 Khz: (ON/OFF) def: OFF
Num: def: Classics UIT
Style: def. classics Theme
BT Model: def-WO BC6
Camera Channel: def: Old Channel 8
Air Supplier: def: default
airbox baudrate: def: 38400
[can baudrate: def: 38400
Value
Power button function
The resistance of the steering buttons
Zap
Remember the volume level when you turn off
The sound of the media playback when moving
The orientation of the touch-screen
The orientation of the image on the screen
Adding " TV " to THE mode source list
Type of backlight control (MCU)
The color depth of the screen (MCU)
Display installed software from Google APP in the Programs menu"
Save the presence flag of the boot animation when exporting settings to a file
Advanced equalizer
Kam
Selected built-in navigation (Chinese programs)
Display of parktronics (MCU)
USB V1 mode.1
Antenna power management (MCU)
Display frequency
Sound Parktronic (MCU)
If you activate the on-Board computer for some cars
Style of the top curtain
[Bottom bar style
Type of WT module
Type of multichannel camera
Type of climate control
[Speed of data exchange for climate control
The speed of data exchange with the can-adapter
Sent from Mail for Windows 10
Wayne Stella
Goose Creek
That is a lot of settings. I'm not sure I know how to get to all of them. Some, using the 7891 pword I think. Anyway, I'll be calling Phoenix in a few hours. I will post what they say.
SitKneelBend
St. Louis
3.6 Pentastar
7890 and then 8861 for the advanced menu...
Wayne Stella
Goose Creek
Thanks. I spent over 30 minutes on a video chat with Eric from Phoenix. I tell you they have been good about helping me like that. Bottom line is they are sending me a new radio. We double checked all the wiring connections and still had no screen. Eric figured something internal had gone bad. It happens. But they have already submitted a new order to have the radio sent, from China unfortunately, only this time they are not waiting for me to send the wrong one back like they did when I received the wrong radio. I'm going to be chomping at the bit until it comes in knowing now what it looks like in the dash (awesome!) and all that it can do. And not being a stereo geek I think the radio/sound portion sounds great. Come on DHL.
SitKneelBend
St. Louis
3.6 Pentastar
Did you happen to ask about the auto headlights issue?
Wayne Stella
Goose Creek
I got so wrapped up in trying to get the radio going I forgot. I'll send him a text later today and ask the question. I'm guessing he'll reply since we just chatted yesterday. I'll post and let you know what he says.
Wayne Stella
Goose Creek
I sent Eric from Phoenix a text asking about the headlight issue. He responded right away and said they are aware of the issue and have contacted the manufacturer who is supposed to be working on a fix. I guess for now its just use the headlight switch manually or leave them on during the day.
SitKneelBend
St. Louis
3.6 Pentastar
Thank you! I really appreciate you asking for me. I came by mine honestly, but I didn't purchase from them and many of these resellers don't answer questions.
SitKneelBend
St. Louis
3.6 Pentastar
FYSA...do not try to add the fastboot firmware to an earlier slow boot Tesla style Android Radio. It won't work...
On another note, I'm really getting this thing dialed in. Has anyone happened to have purchased a screen protector for one of these? I'm looking for one with a bit more of a matte finish...9a20bd23f76686636542ad6434b6a7c0.jpg7c1f7f71e86c64bdf448b2f4116a27b7.jpg
Wayne Stella
Goose Creek
I hadn't thought about a screen protector...........we'll see after I get the replacement radio. Still no information on shipment.
jbdbloh7
Maine
First, for all the early adopters, thanks because of your willingness to try new things we all benefit.
Now, here is my question. I have been doing significant research regarding the feasibility of installing one of these radios in my 2010 Ram 2500. I have found lots of answers that say it cannot be done, most referencing the CANBUS and all the factory controls. Since my truck doesn't have uConnect and all those fancy options, based on what I have read it could function like most aftermarket radios with the options I want such as gauges for engine statistics, etc. but that leaves questions about the climate controls that would be misplaced in the process. I realize there could be significant effort to retrofit the dash to work, but I would really love to have the size screen for my back up camera (I have poor eyesight) among other things.
Also, one of the pages in this thread, someone with an express mentioned something about installing the audio controls in his steering wheel (assuming they did not come factory). Is there some information about this available? I would love to have that in my truck. Any help or insight would be appreciated. I have posted about this upgrade in several FB groups and no one has even responded. I am new to the RAM scene, but am very excited to see what others have done.
SitKneelBend
St. Louis
3.6 Pentastar
Unfortunately, unless you know how to write the code to control your HVAC and have all of the harnesses and pin-outs for older RAM radios, this mod is not for you.
Your best bet would be to upgrade your radio to some other aftermarket solution and or the highest tier OEM radio that was available for your year.
