Tranny oil change - 8 speed
RamFP620
New Jersey
So to make sure what I've read concerning a tranny oil change.....
1. Drain the pan using the drain plug
2. Remove the pan
3. Re-install the new pan, like the one from Dorman since it has a removable filter
4. Jack rear end up to get tires off the ground
5. Make sure tranny is level
6. Fill the tranny from the fill hole until fluid starts to flow back out of the hole
7. Start engine
8. Cycle tranny through the gears - also get tranny to shift in to 2nd
9. Check fluid level and add more until fluid starts to dribble out of the hole
10. Repeat 8 and 9 until fluid is dripping out of the hole and no more fluid can be added
How many quarts of fluid should I purchase? It seems that I won't need the full amount as specified in the manual. Should I get the ZF Lifeguard 8 or equivalent like Amsoil?
Burla
Army
2010 Hemi Reg Cab 4x4
Maxlife multi use = to zf8 fluid, if you want a little performance amsoil multi would be the choice. Amsoil has better performance in the hot and cold as shown pour points and cSt operating visc. There is no compatibility issues around any of these, they would all mix and match.
Amsoil multi
Vis @ 100, 6.3
Pour point, -65c
VI, 159
Maxlife multi
Viscosity at 100°C 5.9
Pour Point -42c
Add a impressive VI at 163
zf8 fluid
Viscosity at 100°C 5.6
Pour point -42°C
R
RamFP620
New Jersey
R
RamFP620
New Jersey
Which one of these from Amsoil?
Burla
Army
I don't know which ones the zf guys are using to be honest, I know that so far so good with amsoil in the zf8. You might want to pose that question for guys using amsoil in the zf.
EdGs
FL
@Wild one has posted factory fill instructions throughout this site. Follow them.
You have to be done with the fill procedure before the trans temp hits 122° F. also. Doable, but you will be very close if not over, unless you start completely cold and it is cold out.
You will have to get the rear wheels up about 9 or 10 inches or so for the pan rail to be level.
Make sure you have the vehicle supported and properly blocked.
Before you remove the pan, make sure to break the fill plug loose on the side of the transmission. Hercules must've been working on the line when mine was filled, that sucker was tight.
I only got about 4-1/2 qts. out of mine on the drain, but the fill took about 5-1/4, so mine was down a little. Not sure why.
I used OE Mopar fluid in mine (just my preference). Some here have used Valvoline Maxlife, Amsoil, Red Line, etc. Your choice there.
Best of luck with your fluid swap, may it go smoothly.
Burla
Army
redline would be d6, but we have had some guys love it and some guys find it too slippery, it for real would have great performance in a zf that gets too hot, but I'd use amsoil before redline as there havent been any reports of slipping. And since it is rumored that I am mr redline around here, that is saying something?
And for sure the amsoil to use is SS and not OE, I didnt notice that from link til Ill looked a second time.
HEMIMANN
Minneapolis, MN
2017 2500 Laramie Crew Cab
6.4L HEMI
Without question I would go with Amsoil Signature Series Synthetic Automatic Transmission Oil. It has superior published typical properties compared to the others, and Red Line pricey "fix it" properties aren't needed for this excellent transmission (unlike the Hemi engines).
Amsoil seems to have come out with a "Fuel Efficient" ATF version targeted to the ZF 8HP70 transmission specifically. Not sure what the deal is here, compared to the previous Chrysler RFE transmissions.
Here is their online selector tool. Call and ask them. https://www.amsoil.com/lookup/auto-...l-8-cyl-engine-code-t-ezh-1/?volume=us-volume
Mister Luck
cassis tutissima virtus
WEST COAST
5.7 V8
Small details like removing the fill plug and releasing fluid before removing the drain on the pan.
The pan will have some residual fluid left as you lower it, and when pulling the pan off you need to check and make sure the O’ring from the filter didn’t slip off and stay inside the valve body.
(Edit)
When refilling fluid temperature monitoring is critical
Using the cluster gauge in the dash is not sufficient.
Monitoring transmission temperature should be done with a quality scan tool with that option.
BigTex13
EMT
HEMI 5.7
I just had my 2015 1500 at the dealer to have my clockspring and steering wheel wiring replaced ND when I asked them about changing the transmission fluid, I specified just changing the pan/filter/drain&fill, they said they wouldn't do it since it is lifetime fluid. I'm hesitant to do it myself because I don't want to mess anything up with the transmission since I don't have any way to monitor temps. I guess I'll have to find a reputable local shop willing to do it and use Amsoil fluids.
PoMansRam
East Aurora NY
Mister Luck
WEST COAST
5.7 V8
I agree with using Amsoil for the ZF
The difference I believe between the ZF and the RFE is the response time of shifts the ZF can change gears in 400ms
The ZF is lighter in overall weight and is able to handle greater torque values. FCA USA uses Chrysler’s Kokomo transmission plant to produce the ZF with permission of ZF GROUP in Germany. Part of the agreement is to share research and development between the rest of the Groups participants,
BMW , Porshe Audi VW, , Lamborghini including software as
well as mechanical enhancements.
joesstripclub
Kansas City, MO
2021 2500 PW
I jack the rear of my truck up and set it down on the highest level my jack stands go and its still not quite level. If you have larger jack stands it might get level but I havent had any issues with the fill level from my procedure. Just make sure whatever you do to not do the fill procedure on just a jack. Otherwise I think you have all the steps down. I've done mine 3 times now (long story) and its a pretty straightforward process. I also highly recommend a HD sprayer for your fluid fill. Simply take the wand off the trigger and install a length of tubing that is the same diameter. I cant remember the size, 5/16 maybe?, but its easy to find at HD while you grab the sprayer. Easy 1 person operation and it will even pump diff fluid when you get to that service.
Mister Luck
WEST COAST
5.7 V8
The lifetime oil rating decal is placed on the transmission by the vehicle manufacturers not at the specifications of the transmission designers (ZF Friedrichshafen) besides the 100,000km / 60,000 mile service interval , other extenuating circumstances are severe service or unknown service life as with previously owned vehicles.
High end luxury cars like Bentley Lamborghni Mercedes etc. incorporate the use of the ZF giving the service specifications an added aristocratic premise and with that the added responsibility of comebacks and legal obligations, the average repair facility is not willing to marry into without a previous service relationship.
Or if similar relationships had a falling out.
DA Smith
Marshall Texas
If they don't want to change your Trans fluid have them sign, date , and have the disclaimer notarized to the fact that they said fluid is lifetime and will not change it. Just drive and enjoy your truck and if the transmission fails they can replace it with a new one when you whip out their signed copy of their ignorance!
Midknight
New Jersey
Some little things from my experience doing this:
Jack the truck up first and crack fill plug as noted by others. I needed big 10 ton stands for the height. I used smaller stands for safety in other locations in case something kicked out. Extra safety!
Unbolt the pan from one end (tilting) to allow the fluid to drain before dropping. You won't be able to access the drain plug.
The pan can be a close fit when trying to remove it. Be careful and use finesse and not brute force. Same goes for reinstalling new.
Absolutely get a pump, I used a cheap battery electric one from Harbor Freight. Makes getting the fluid in fast enough without getting over temp. This was the best trick and saved seroius agrevation since it was dark for me.
Good luck, it's not that hard after the first trial.
Roadwarrior1500
OHIO
Regarding what fluid; I have a 2017 8 speed, Hemi, Crew and went with the Amsoil, changed it at 100k. It didn't seem to shift smooth at first. Had to take it to the dealer and they did a "Re-learn" with their scanner. Took about 300 miles to learn my driving habits.. Ever since the re-learn she shifts great and runs 10 degrees cooler. I have 195k on the truck now and no issues with the trans. Not one to believe in "Sealed for life" when ZF tells you to change the Fluid and FCA's customer service has no clue.
