Tranny temp reading -13*F this morning!
Newramguy260
6.4 hemi
So, I went out to start my '18 2500 Tradesman this morning. While letting it warm up a bit, ( there was a tinge of wet frost on the windshield, and 37* outside temp! Winter is coming! ) I noticed the Tranny temp was -13 F . After letting it run for 10 minutes, it still only read 5*. There is only 587 miles on this truck. It has already been in the shop for a transmission temp sensor issue that lit up the check engine light. Now it's on again. The service department says it's safe to drive as long as the light isn't flashing.
Thoughts, opinions, experiences, would be appreciated. Thanks!
McBroom
Denison Tx
Hemi 6.4L
********! It needs looked at. Go to a different dealership
Blue Streak Pearl off-road
RoadRamblerNJ
Knoxville, TN
392 Hemi
It seems they didn't fix the problem on your first visit. I'd be going back to the (any) dealership asap.
17CrewCab1500
There is a communication issue between the two. I would take it back or take it to another dealership for sure.
Ratket
Arizona-
There are probably “Safe guards” that limit the truck until that tranny temp comes up to operating temperature, and it is prolly not helping anything or running correct with it reading a -13* temp, I would get it looked at ASAP.
Jimmy07
Definitely something wrong with the temp sensor or the way it’s being read. The threshold on mine is 35F. It won’t read any lower than that. There is a safeguard for the trans for low temps. The torque converter won’t lock up and trans won’t shift into 6th until the trans temp reaches 65F.
RamCares
n/a
n/a
Thank you everyone! The dealer i bought the truck from can't get me in until the 8th, So I will be taking it to another RAM dealer on Monday.
Hi Newramguy260,
We're glad to see that you are having a dealer look into this. If you would like any extra assistance or have any questions or concerns while your truck is being serviced, you can send us a private message and we would be happy to help.
Lydia
Ram Social Care Specialist
Newramguy260
Newramguy260
6.4 hemi
Hi Newramguy260,
Lydia
Thank you.
Newramguy260
Newramguy260
6.4 hemi
Brought my truck into the dealer tonight. This time they say "It must be the battery" and they are going to put in a new one. I'm not a certified technician, but it would seem to me that a -13 degree reading would point to a faulty sensor. Are they just d@#$ing me around because its a time consuming fix? Guess I'll find out tomorrow!
When I started it up tonight to bring it to dealer, tranny temp read -2. It was 57* outside...
RoadRamblerNJ
Knoxville, TN
392 Hemi
Well, they'll know right away if it was the battery. Don't see how it could be. You're on the right track looking into the trans temp sensor. I hate computerized vehicles.
RoadRamblerNJ
Knoxville, TN
392 Hemi
Seriously? The friggin' battery? 12 volts is 12 volts. You either have it or you don't.
Hey, maybe, just maybe you still have the Summer air in the tires and we've passed the Fall equinox already. Wrong tire air is probably affecting your trans temp.
Newramguy260
Newramguy260
6.4 hemi
Alright, So update time. Turns out there was a loose pin in the 23 way Wire connector. So the dealership replaced the entire thing. Bonus: The salesman slipped up and mentioned they had to jump start the truck when they brought it around, So the installed a new battery as well!
Drove her home tonight. Tranny temp started out at 120* and 25 highway miles later, was 158*. Hopefully problem solved and I get log some miles that don't involve going back to the dealer!
P.S Pray for snow! I can't wait to start pushing with this baby!
GsRAM
2017 Dodge Ram 2500
Hemi, 6.4L
Glad to hear they figured it out. To the others who were so quickly dismissive of the battery as a potential cause, next time don't be so quick to pass judgement. Today's vehicles are very sensitive to battery voltage and amperage. If it's not right they can do some pretty quirky things, yet otherwise start the engine and seem otherwise ok. I've seen it many times
Ftank
