Mister Luck
cassis tutissima virtus
- Joined
- Aug 25, 2020
- Posts
- 1,651
- Reaction score
- 589
- Location
- WEST COAST
- Ram Year
- 2016/2017
- Engine
- 5.7 V8
Then I would say that you do not have the BW44-44Interesting, cuz my truck has the bw 44-44 and I don't have the auto option...
Actually I do...I just changed the fluid and the label on the tc said 44-44Then I would say that you do not have the BW44-44
If memory serves me correctly both transfer cases use the same casting for the case, just the front output shaft is bigger on the BW44-44 due to the clutch. Visually they both look the same, need to look at the actual Ram part number.Interesting, cuz my truck has the bw 44-44 and I don't have the auto option...
The label on the case says 44-44If memory serves me correctly both transfer cases use the same casting for the case, just the front output shaft is bigger on the BW44-44 due to the clutch. Visually they both look the same, need to look at the actual Ram part number.
Mopar even specs the same fluid for both.
That is 09-12 ?
The plot thickensIf memory serves me correctly both transfer cases use the same casting for the case, just the front output shaft is bigger on the BW44-44 due to the clutch. Visually they both look the same, need to look at the actual Ram part number.
I don't think anyone came down with definitive proof but the consensus was they clutch/material used in the '16 and later BW44-44 changed, that's why there was a fluid spec changed. Best guess is there is a friction modifier change with the fluid.Why are there variations in the applications of the 44-44
and 44-45 transfer case for the 4 generation 1500 ?
I would advise against testing it this way. Too much stress on the gears.If you want to test if you actually have a BW44-44 put the transfer case in 4X4 Lock and drive in a tight circle on dry pavement. If the front end fights and/or hops you have the BW44-45
Not if you have the BW44-44, the front drive doesn't engage fully unless wheel slippage is detected (even in 4X4 Lock).I would advise against testing it this way. Too much stress on the gears.
You don’t need much of a turning radius to experience the “hop”I would advise against testing it this way. Too much stress on the gears.
Friction modifier additives for transfer cases would be the same as for transmissions or for differentials ?I don't think anyone came down with definitive proof but the consensus was they clutch/material used in the '16 and later BW44-44 changed, that's why there was a fluid spec changed. Best guess is there is a friction modifier change with the fluid.
There is nothing that changed with the BW44-45 as it's a part-time transfer case and does not utilize a clutch pack. Ram specs the same fluid for it to simplify service.
