Transfer Case Controls Quiz
Mister Luck
cassis tutissima virtus
WEST COAST
5.7 V8
Image 1 44-44 ? with the auto button
Image 2 44-45 ? without the auto button
Which transfer case controls are for
a 44-44 ?
a 44-45 ?C6EC2C23-DE22-4128-8C99-E7525EA9B862.jpegB4F982CB-7B15-4975-AA50-5868AD2C44AD.jpeg
The BW44-44 uses the Auto 4X4 button, the BW44-45 does not have the Auto option.
MontanaHandyman
Montana
Interesting, cuz my truck has the bw 44-44 and I don't have the auto option...
Badger 13
North Idaho
2013 Dodge Ram 1500
The pictures show the trans shift knob, and not the transfer case position. Am I missing something with these pictures ?
LouM
Marine Corps
Greeenwich/Easton upstate NY
2015 Ram Ecodiesel crewcab old/ 2019 Laramie Hemi old/ 2022 RAM 2500 6.7
eco diesel old / now Hemi missing the eco's mileage/ now back to enjoying diesel torqueesel
When you enlarge the picture the T case buttons are visible.
LouM
Marine Corps
NOV87
PNW
Top picture has AUTO (BW 44-44).
Bottom doesn't have AUTO (BW 44-45).
Out of focus pics. Hard to tell...
If memory serves me correctly both transfer cases use the same casting for the case, just the front output shaft is bigger on the BW44-44 due to the clutch. Visually they both look the same, need to look at the actual Ram part number.
Mopar even specs the same fluid for both.
If you want to test if you actually have a BW44-44 put the transfer case in 4X4 Lock and drive in a tight circle on dry pavement. If the front end fights and/or hops you have the BW44-45
MontanaHandyman
Montana
The label on the case says 44-44
Mister Luck
Mister Luck
WEST COAST
5.7 V8
The plot thickens
Why are there variations in the applications of the 44-44
and 44-45 transfer case for the 4 generation 1500 ?
I don't think anyone came down with definitive proof but the consensus was they clutch/material used in the '16 and later BW44-44 changed, that's why there was a fluid spec changed. Best guess is there is a friction modifier change with the fluid.
There is nothing that changed with the BW44-45 as it's a part-time transfer case and does not utilize a clutch pack. Ram specs the same fluid for it to simplify service.
I would advise against testing it this way. Too much stress on the gears.
Not if you have the BW44-44, the front drive doesn't engage fully unless wheel slippage is detected (even in 4X4 Lock).
You'll get immediate feedback if it's the BW44-45, hope one will get the hint to not keep the wheel turned.
Mister Luck
Mister Luck
WEST COAST
5.7 V8
Friction modifier additives for transfer cases would be the same as for transmissions or for differentials ?
Some transfer case fluids are rated for fuel economy and others for longevity and thermal break down. ( lower and higher viscosities )
But additives are strictly to combat metal fatigue
like a friction modifier ?
