Transmission help!!!
Rjax
San Diego
Tranny is stuck in 4wd and wont shift out of first gear. I can switch between 4hi and 4low but does nothing when I flip into 2wd anyone had this problem before?? I did some pretty intense mudding today and didn't notice anything until I hit the road on my way home.
steermaster
CO
5.7L
ooooooo buddy....I did the same thing in my 06...thought maybe it was the neutral safety switch for some reason... I had to get full rebuild :( GOOD LUCK!!! call some trans shops around you and see if they will look at it for you, sometimes they will do inspection for free, or go about 80-100 bucks in and have them pull pan in inspect throughly...
MyOhFive
HEMI
This is a real Microsoft approach, but have you tried just unhooking the battery for 15 mins or so to reset it?
Tranny stuck in first and t-case stuck in 4wd are two different things.
Rjax
Rjax
San Diego
about an hour after I posted this I went out and took another look at it. I must have a magic flashlight or something, right after that I hopped into and it flipped right into 2wd and what do ya know? No problems! took it for a spin around the block and the highway and it shifted just fine... weird. anyways im still gonaa take it in to get checked out because something is obviously wrong.
