TJP440
EDITED
I would love to converse or slap the
out of the idiot that thought the 8H70 did not need a dipstick and the other one that proceeded to put it in the chassis at the angle they did.
I am almost through with the service having the 15 step pick your nose, scratch your butt crack. Now smell /eat what you found on your finger after the previous steps but only do so in temperatures between 86 and 100 F or your nose and butt may cease to function.
OK enough sarcasm / humor.
I did go with the PPE 1 quart over pan getting it for ~$270 with shipping on my Atech (wholesale account.)
Also bought a new OEM gasket off AMZ for ~ 24.00.
I know they say one can reuse the gasket but not worth 24.00 to go through the first paragraph scenario. Went with Maxlife fluid from Wally World @ 22.00 a gallon x 2.
Didn't know which way the gasket went on but figured out the "nibs" hold it into the machined groove on the pan.
Installed the new gasket on the pan, some attention to the alignment of the holes and making sure the gasket seats properly is required. Haven't seen these two mentioned anywhere so I thought I'd throw them in. I assume the raised rib on the top of the gasket slips just inside the case/housing. In hindsight, I would've wiped a film of fluid to help it do so. Maybe next time
Locating the filter was not too bad but it does require firm pressure upwards on the bottom to get the filter tube in, again a little fluid may have helped.
Once in place with 2 screws holding it the remaining ones were installed finger tight. The remaining ones followed. Once all were in, following the torque pattern they were slowly tightened a few times until all were snug.
I believe the above step is critical to align the top gasket rib with the case as well as not tweaking the pan or damaging the gasket.
Again using the pattern, they were then torqued to 72 in lbs. Based on another's experience, I did remove the drain plug and found a DRY O-ring with a few small pieces of aluminum. I cleaned everything, removed and inspected the O-ring. Reinstalled with a bit of fluid on the O-ring and recess it goes into.
Next, how to get the fluid in the easily accessible opening. I found that by peeling the carpet back and drilling a 1 inch hole in the floor pan (gotta love Uni bits
) I was able to use a funnel with a hose. but then I found if I poured the fluid to fast it would splash back and make a mess. Refer to first paragraph.
OK forget the last paragraph
I bought an extra fill /drain plug Dorman # 090-167 (18-1.5mm). Drilled and tapped it for 1/8 NPT. Using a 5/16 barbed elbow with a clear vinyl hose I now had a secure way to get the fluid in without making a flipping mess. I attached the other end of the hose to an extra 2 qt garden sprayer I had (~10.00 at wallyworld). Filled it with fluid and pumped 6.5 qts. in without spilling a drop.
Tomorrow is first paragraph day and should be done
Hopefully some of this will be helpful to another
out of the idiot that thought the 8H70 did not need a dipstick and the other one that proceeded to put it in the chassis at the angle they did.I am almost through with the service having the 15 step pick your nose, scratch your butt crack. Now smell /eat what you found on your finger after the previous steps but only do so in temperatures between 86 and 100 F or your nose and butt may cease to function.
) I was able to use a funnel with a hose. but then I found if I poured the fluid to fast it would splash back and make a mess. Refer to first paragraph.OK forget the last paragraph
out of your arms and hands removing (BUTT?) fill plug. If dysentery is present burn yourself again putting plug back in. IF not pump fluid into orifice until it dribbles back out.
