Water
Duflick
Evans, Ga
I have a 2017 dodge ram 1500 5.7. When i pull of, i hear water rustling near the glove box. I topped off antifreeze. Cleared out hvac drain. (It was dry after i ran the ac). Checked for leaks around water pump. Floor is not wet and no obvious signs of leakage. Any thoughts?
tron67j
Maryland
The coils in your heater core are contracting or expanding (depending on what you were running) and/or condensing the moisture in the air. Kind of how a in-window air conditioner sounds when you turn it off?
D
Duflick
Evans, Ga
Thanks for responding. So that expansion will sound like water running behind the dash. Sounds more like water than air.
jws123
nj
You have air in your heater core if you coolant went low you need to re burp the system/heater core.
D
Duflick
Evans, Ga
rule18
Admin
NY
2017 Rebel
Moving this over to the 4th Gen section.
D
Duflick
Evans, Ga
Seems like the heat will fluctuate from warm to cold.
