Burla
- Apr 28, 2012
- 27,558
- 57,801
- 2010 Hemi Reg Cab 4x4
- Hemi
Well yeah there is not much they can do, as you see in the chart the issue is you lose capacity in the cold and hemi's need more CCA then most vehicles. I would put a battery blanket on it and as much insulation as I could. I would be careful with a battery warmed blanket for the same reason on the chart, cold kills capacity and warm kills lifespan. Unless you have a battery warmer at 77f then I would avoid that.Sad. I have a 2024 RAM 2500. We have had some unusually cold weather this month, -40's. My battery failed after less than 12,000 miles and 17 months. Called the dealer in Fairbanks. I was shocked when they told me that RAM does not warranty the battery in Alaska, it's considered wear and tear. I haven't had time to check if that is true or not. Anybody know? Needless to say, it will not be a MOPAR battery replacing it.
