JimirigRam
Hello -I’m wanting my 4th gen Ram 5.7 to run cooler while towing (a 4500# camper), but would rather not swap the stock thermostat to avoid codes. While towing(before current mods), Engine runs 230-235 and oil is 240-250. Trans 195-200.
I’ve installed a v6 electric fan & deleted AGS and plan on installing a tuner. I also plan to install dual remote oil filter kit.
With the tuner, what temp setting do I use to turn the fan on and off with the 203 stat? Is there a quality 193ish thermostat on the market I should consider?
What else can you recommend to help the engine run cooler while towing with minimal mods. Looking for longevity over performance.
Thanks in advance!
Thanks in advance!
