A dry filter is thrown away after it is dirty and replaced with a new filter. Oiled filters are not thrown away. You simply clean, and oil them, before putting them back in the air box. It's all your personal preference. I prefer gauze filters that you oil, other prefer the paper filter that are disposable. Paper filter have come a long way and they have just as much flow as a gauze filter.
You are correct RUdone21. Matt, Moe's, has them listed for $30.00. Im not sure how many times you can clean/oil the filter with one kit. Im sure someone will chime in with the answer.
Just saw that cleaning and oil kit for $30. How much are the replacement filters if I decide to go with the dry filter option? I didn't see replacement filters on Moe's website.
I didn't see the replacement filter either. Im sure Matt will chime in shortly.
I just noticed that Moe's website says the dry filter is "cleanable". Maybe it's not throw away after getting dirty?
I never noticed that until now. That might be the best of both worlds.
What's the best way to get a solid answer on this ASAP? I plan on placing an order tomorrow so that I can get it on or before Friday. Thanks.
Call Moe's first thing in the morning. He will take care of you.
Yes, there are differences. Let me try to explain, hopefully in a understandable manner, without injecting too much opinion into the subject. Of course, these explanations are overly simplified, but hopefully they may help.
Dry filters, in general, use a more restrictive filter media (smaller openings between the fibers) to keep dirt and contamination from getting into the engine. Some people consider this to be safer for the engine as it filters out more contamination, while others feel it can choke the engine somewhat due to it's more restrictive media.
Oiled filters, in general, use a less restrictive filter media (larger openings between the fibers) and add an oiling process to the filter to help catch some of the dirt and contamination from getting through the larger openings (like flypaper for dirt). Some people consider this to be less restrictive and conducive to better airflow, while others feel it leads to more contamination entering the engine.
So now, imagine that you can shrink yourself to say, the size of a few microns and are standing in front of a dry filter and an oiled one. If you looked at a dry filter, you would see that the openings in the dry filter media are smaller than you, so if you try to walk through, you can not. If you looked at the oiled filter, you would see that the openings in the filter media are larger than you, but they are also oiled so that if you touch them while going through, you will stick to them (like fly-paper). However, if you don't touch the fibers while walking through the oiled filter media, you will go through with no trouble.
So in the end, it comes down to a personal preference type of issue. Is the "possible" added airflow of an oiled filter worth the "possibility" of more contamination getting through to your engine? I use quotes because neither possibility (pro or con) is guaranteed.
Thanks for all the help!
