Have not had a chance to hook up the AE to my truck yet, to see if I can get the remote start heated seat and wheel function back. On stock 8.4 trucks this function can be toggled on and of thru SETTINGS/ AUTO ON COMFORT & REMOTE START or so it says in my 2014 owners manual on page 316. For trucks not equipped with the 8.4 IE bighorn the setting supposedly can be toggled in the EVIC under personal settings , page 316.
I looked for this setting in my radio (no gots) need to check the EVIC. I wonder if the AE has the ability to add the option settings to the Radio or EVIC?
I suspect that the reason I no longer have this ability is the donor truck had disabled this feature and the seat module is "SET" to not use Auto on comfort. So one of my options would be to swap the modules. But I still have hope that when I clear any DTCs the function will return.
There are a few such situations where we do not have control of or can toggle on and off certain functionality. For instance Nav displayed in the EVIC, there is supposed to be a menu setting in the radio for this, very few folks have upgraded from RA1 or RA2 seem to have this setting, yet it works but if we should loose it we have no way to turn it back on. I remember also when we first started the 8.4 mod some guys auto dim mirror worked yet they had no soft key to toggle, mine did not work until I recently added the soft key.
What I am getting at and it sucks in some cases is that for some items we may be at the mercy of the settings as they were in the donor vehicle. Anyway if it ever warms up enough (8 degrees this morning) going to get out there and plug in the laptop.
Rick, Deereguy, 00R/t or anyone else do you have the Auto comfort setting in either the radio or Evic?
