Grabbing this one if needed..
** Cautionary warning about where you buy a 2018 ram UAQ or UAS Radio from see post 2420. **
------- Dec 2020 -------
Here's also a recently verified Ram radio PNs
2020 Ram 1500 classic (Thanks
@Brads41789 Post Here )
- PN: 68461703Ax (UAS 4c)
2020 Ram 1500 Classic (Thanks
@dwhutch post here. Verified later.)
- PN: 68461699Ax (UAQ 4c Nav)
* If you are upgrading from a 3.0 or 5.0 radio to an 8.4 (13-17 Harmon or Panasonic, here's a link to the 8.4 conversion thread for details (start at post 1, 2 & 3). You will also need ATC in most instances (13-17 trucks definitely. 18/classic trucks are 50/50. See below).
DIY: 2013-2017 RA3/RA4 8.4" Radio Upgrade/HVAC Conversion.
(Resurrected thread after it was deleted again)
------------------ 4/25/18 edit ------------------
Just an 'issue' update for those installing the UAQ/UAS radio in their truck...
We had several reports:
See: Gibbs' .
HVAC Issues w/UAS upgrade.
& Outback199 's 19Classic w/same issue at
post 138 ... and the
outcome at post 269 here.
A lack of 'full' heat after radio install using the previously recommended 13-17 HVAC modules from the earlier Ra3/Ra4 upgrade method. (Blend door not making full travel & jumping from full Hot to full cold only!)
** EDIT: adding ATC option fixed issue on all cases including those where HVAC module swap didn't and allowed 13-17 modules to work **
- Guido2112 's 17 1500 (fixed w/new module)
- Gibbs ' 18 2500 (fixed w/new 18 module)
** Ckleinfeld 's 15 1500 (used mod. didn't work). .
See here
We have identified the correct 18 HVAC modules ...
Code:
As DeereGuy stated, it appears that on 2018 trucks ...
- 68366552AA = 2014+ 1500 trucks w/8.4 radios (MTC & ATC)
ie factory 7 speed fan (w/Variable Displacement A/C Compressor)
- 68366553AA = 2013+ 2500/3500 & 2013 1500 trucks w/8.4 radios (ATC)
ie factory 4 speed fan (w/Sgl speed A/C Compressor)
Post 87: Comparison of compass hub vs ram hub & install videos
Also:
Here's how Sawz fixed the 2018 USB hub cutout issue on his earlier console.
See here.
-------- 1/15/21 Update -------
Possible 2017 Chrysler 200 Dual USB Hub that fits better (minimal sanding) and is reported to work with the UAQ/UAS.
See
Post 2767 here.
- P/N: 68283703AA 2017 Chrysler 200 - dual USB with AUX inputs.
Confirmed by Ezyduzit23 post 3094
post 3094.
------------------- 10/18/19 Edit: --------------------
For those that want to purchase the entire 2018 Console Lid Assy (includes premium dual USB hub & 2018 lid wiring) here are some PNs and pricing from forum Vendor Benny at AllMoparParts.com ...
** Please see my post in CircuitGuy's Dash swap thread,
post 40, for details about the panel light wiring mod if installing this in a 13-17 console truck (or it may drain the battery just plugging it in)**
$317 - Rebel Red stitch:
5YE031XRAG.
$403 - Rebel White Stitch:
6RD67XDBAF.
$*** - Rebel Blue Stitch: (pm Benny)
$646 - Laramie/BigHorn Std Black:
6RD73DX9AF.
$970 - Limited White Stitch & logo:
6RD71BD3AF.
Edit:
Post 1047 - Possible remote USB port option (doesn't work)
