REAR WINDOW FRAME CRACKED
Tombato
Massachusettes
2019 New Body
Also have the crack but not 100% sure if it leaks. reading this thread because I noticed the floor really wet under my rear seats after some heavy rain recently. going to monitor.
turkeybird56
Central Texas
I would not monitor, U gonna have mildew issues etc, best get into dealer before U run your 3 year, 36K warranty out. But alas, your ride.
brian42
San Diego, CA
You fall in line with STAR Case S2023000024. That is clearly a crack and not a knit line. This is how I got my rear window replaced:
  • STAR Case S2023000024.pdf
BigA
Ohio
5.7 Hemi Etorque
My 2019 just cracked at the Knit Line at 50,000 miles, sat out in the rain for 45 minutes and sure enough water started coming in through the crack. out of warranty got a quote from the dealer and the glass shop. Not going to pay $300 extra for the dealer to sub it out to a glass shop anyway. Glass shop said should be about 10 days to get the OEM window.
JF19Longhorn
South Jersey
5.7 ETorque
They have to remove the headliner, 3rd brake light, and backseat. So make sure they put everything back correctly and don't mess em up.
BigA
Ohio
5.7 Hemi Etorque
yes, I didn't know about the headliner, will defiantly be checking it over good.
SixAddict
Phoenix, AZ.
2019 Ram 1500 Laramie
I just discovered that my rear window frame has three or four cracks in it. I don’t think it’s leaking as several car washes show no leaks…..yet.
The sad part is two stealerships have basically blown me off with the old “we are so busy you’ll have to leave your truck with us for four or five days before we can look at it”.
How pathetic, I can’t be without my truck for a week to have some gomer say yep frames cracked, golly gee.
Never again.
brian42
San Diego, CA
If you dont' take it in it won't get fixed (if your truck is still under basic warranty).
If that's all you need done then you should be able to take it in, have the service advisor verify the cracks to authorize the repair, then call you when the rear window comes in to bring your truck back.
You will have to give them the truck for a day or three to get the job done (they most likely will outsource the job to a nearby glass shop).
SixAddict
Phoenix, AZ.
Yes that’s all I wanted to do was drive it in have the service advisor confirm said cracks, then schedule and I would drop the truck off.
He said he has to have a technician look at it and would need my truck for four or five days before someone can look at it. That is insane, just to confirm cracks would take all of five minutes.
Mpgrimm2
Preferred Vendor
SC
2022 Ram 1500 (5th Gen)
5.7L
I thought hey usually want to run a hose/pressure washer, etc over the window to confirm it's leaking vs just cosmetic cracks before they push to get the window replaced.
I took pictures of inside of the rear window leaking near the cracks on mine and emailed it to the service advisor the day I first brought it in.. That and the obvious cracks where he saw it was enough to schedule the replacement and order the window. (They also have to remove the back seat/interior panels around the window before sending it off to the glass shop.)
They should be able to still schedule a day or two to look at it and drop it off the night before.
SixAddict
Phoenix, AZ.
So if my window isn’t leaking, do or will they still replace trim piece under warranty?
Just asking if you know. Thanks.
I have been thru several car washes and noticed no water, unfortunately living in AZ we don’t get much rain, so I can’t say it leaks when it rains….lol.
Mpgrimm2
Preferred Vendor
SC
5.7L
I don't know what they'll actually do in your situation
brian42
San Diego, CA
My dealership's schedule is at least a month out for an appointment. Once I drop it off it's put into the "rotation". It's at least 2-3 business days before it even gets looked at.
It's the nature of the beast in this day and age. Pre-COVID there were 4 service advisors and a service manager. Now there's one advisor and one manager. I can only imagine what the staffing is out on the service floor.
There's a STAR Case that does not require a water test. If they are seams then they would go to the water test if you press the issue but it they are cracks then the window gets replaced.
They have no idea when your truck will be "called up" from the rotation to be looked at. If they let everyone come back that would double the workload of the already overworked staff.
There is no "trim" piece to replace. The whole window assembly is all one unit so it's all or nothing. That's why there's such a guffaw over this. Technically the frame could be covered under an extended warranty but glass is definitely not. Since you are replacing the glass when you replace the frame is why it is not covered outside of the basic warranty.
SixAddict
Phoenix, AZ.
Just wanted to update this thread and my situation.
After two dealerships gave me the runaround I went back to the dealership I purchased my truck from, it’s a little bit of a drive further for me, than the other dealerships.
Upon my arrival at appointed time I met with service advisor and explained my situation and why I was there. He laughed and informed me there was no reason I had to leave my truck, he could handle the issue on the spot.
He took photos of the rear window trim cracks and gave me a reference number and told me he would be in touch when he found out how long it would be to get parts ordered and in house.
On my way home he phoned me and said parts are about a week out and would call and schedule me when parts arrived.
Not sure why the other dealerships couldn’t have done this.
This is a very large dealership and he said they would probly replace rear window themselves as they have a full body shop there also. I had read on here some dealers were out sourcing to glass companies, thats why I asked him about this.
So for now I’m a happy camper, I just wanted to get this issue on record as I’m at 35,500 miles and 35 months.
Will up date after work is complete and see if everything was put back together correctly.
Mpgrimm2
Preferred Vendor
SC
5.7L
... & That is how it's supposed to happen, & not just because you bought the truck there.
Hopefully the difference in your service experience with the other dealers will keep you going back to the 3rd one you bought it from.
brian42
San Diego, CA
Each dealership runs differently. Some have all the departments working together with everything under the umbrella of the dealership and some have departments operating separately so they each have their own finances and bottom line to defend. That's why you get some that will throw in free parts and service if you buy from that dealership and some don't because they can't cross the line and give away another departments goods/services and take from their bottom line.
I don't think corporate has a lot of expectations for the service departments as they don't seem to hold dealerships to any minimum standard. 6 dealerships near me and 5 are terrible.
SixAddict
Phoenix, AZ.
Just to update on my experience. Parts arrived end of week, dropped truck off this past Monday and Wednesday (today) the service advisor called to let me know truck was finished as well as an oil change. We picked the truck up this evening and all looks very well and I can see no issues as of now. If anything develops I will update. Not sure if I got a “newer” rear window assembly or not. Good luck to others with this issue. :waytogo:
M59VOQ
Add me to the list this has happened to. 2019 Limited. 25K miles. Sits in the driveway most days as I work remote. After a recent storm noticed all windows were completed fogged over with heavy moisture. After a few days of the same during clear weather I knew something wasn't right. Brought to dealer and first thing he checked was the carpets under the back seats. Sure enough, it was wet. Left it on a Saturday and today (Weds) it was finally looked at. Turns out rear glass is cracked and needs to be replaced. Waiting on pictures. Barely out of warranty so $1460 out of pocket. Seems like this should be covered as a manufacturer defect. Insurance will cover if cracked, but deductible too high to make it worth it. Drivers sun visor hinge also falling apart ($265) and power steering makes growling noise on slow hard right turns. A 5 minute TSB to flash the chip and fix, $170. Tires down to 3/32 and need to be replaced and I barely drive the thing. Hope this isn't a sign of things to come. Love the truck otherwise. I guess it is what it is, but ouch.
Mpgrimm2
Preferred Vendor
SC
5.7L
@RamCares should be able to help you get this known rest window issue covered, especially if you're just barely past your warranty. (They won't cover damaged/wet headliner etc)
RamCares
n/a
n/a
Hey!
We appreciate being tagged in this! We'd be happy to look into this for you. Please DM us!
Callie
Ram Cares
