evolizzee
Redline 5W30. My 5th Gen has too much on it to have a warranty, anymore. So, I run what the HEMI Ram Gurus recommend.
A "bit of a rep" is not a "claim" as you appear to think.This is the claim I'm talking about, in case you forgot what you said...
It seems that you can't have an adult conversation without personally attacking people. I'm not a vindictive person, but if you attack me one more time I'll have to take action. If you want to keep this a civil discussion then I'm open for that. Consider this an unofficial warning.
I thought the cam and lifter failures were more of a thing years ago under the 5w-20 / 5w30 oil recommendations and that newer 2018 + engines have been behaving better? Dealer does mine so I am guessing 0w-20 water is being used, but any work is in their hands for the next 8 years / 100,000 miles. 0w-20 for improved MPG is a joke, the 15 city 21 highway MPG estimate is for a 4x2 in the small print with what I would guess is a 3.21 gear ratio. My 2022 crew cab standard bed 3.92 4x4 will NEVER see those numbers it seems like. Warmed up cruising on highway 17-18 might be the best so far. MDS seems like a joke as well. I am one who doesn’t care about mpg but just enjoying the vehicle though!A "bit of a rep" is not a "claim" as you appear to think.
I never once claimed anything,i said 5W-20 and 0W-20 have a "bit of a rep",and that's going by the amount of posts about cam/lifter failures.And 5W-20 has a worse rep then 5W-30,just by the amount of cam/lifter failures,with 5W-20 being one of the bigger common denominators.Just go through the posts here and on facebook,and you'll find more cam/lifter issues with 5W-20,then you will with 5W-30. Nobody can prove anything,as FCA isn't releasing the numbers on cam/lifter failures,especially in regards to oil viscosity,but it's fairly common knowledge that lighter oils aren't usually spec'd for engine longevity,they're spec'd for milege and emissions numbers. Just read this again,do you see FCA mentioning anything about engine longevity.But they do mention gas milege, if they thought 5W-20 was better then 5W-30 for longevity,do you think they would of missed mentioning that fact,very doubtful.And just for the record,i mentioned warrenty a couple times in my posts,and that he should stick with what's reconmended if he was worried about his warrenty. I have a question for you,why do you think they started spec'ing 0W-20,when the 5.7 was originally spec'd for 5W-30 ,and the HDs with the 5.7 were still calling for 5W-30 up till a few years ago,what would be their reason for going to a lighter oil in your opinion
Supposedly the later lifters are slightly better,but if you go to the car pages,the lifters are still causing issues ,and as far as the block/cam and oiling system goes a 5.7 is a 5.7 whether it's in a car or a truck.I thought the cam and lifter failures were more of a thing years ago under the 5w-20 / 5w30 oil recommendations and that newer 2018 + engines have been behaving better? Dealer does mine so I am guessing 0w-20 water is being used, but any work is in their hands for the next 8 years / 100,000 miles. 0w-20 for improved MPG is a joke, the 15 city 21 highway MPG estimate is for a 4x2 in the small print with what I would guess is a 3.21 gear ratio. My 2022 crew cab standard bed 3.92 4x4 will NEVER see those numbers it seems like. Warmed up cruising on highway 17-18 might be the best so far. MDS seems like a joke as well. I am one who doesn’t care about mpg but just enjoying the vehicle though!
It might be more of: Ram choosing a bearing that is inadequate/improper for the task. The internal composition of the bearing, Ram uses, doesnt hold up in the conditions it is subjected to. This makes this particular bearing fail in conditions, where more suitable bearings would not fail. Even worse…Ram suggests changing the engine oil every 10k miles. By then, most typical autoparts store oil has broken too much to provide adequate protection to an, already, inadequate bearing. This can accelerate the failure if the owner adheres to the 10k mile oil change interval. This is why the HEMI gurus recommended using a high quality oil with ZDDP additives or high quality oil and a supplemental MolyB additives. They also recommend changing the oil anywhere from 3k-5k miles depending on how hard the vehicle is driven and how modified the engine is. Tuning helps as well. Raising the idle rpms just slightly, increases oil pressure at idle, keeping fresh oil flowing to the upper end of the engine.It's still just speculation as to what's causing it. No one has been able to definitively show that the lower viscosity oils are causing it. Another theory speculates that the design of the block doesn't allow sufficient oiling of the camshaft. Theories and speculation, or even "a bit of a rep" doesn't prove anything. Engines fail, it's a fact of life. Taking care of your engine by performing routine maintenance gives your engine the best chance of not having oil related issues. Whatever the reason, Ram recommends a specific oil viscosity for their engines just like every other manufacturer out there. I suspect Wild one is right with some of his reasons for why Ram went with a lower viscosity oil, but they aren't going to recommend something that they know causes engine failure.
Who are those and what engineering criteria they used for the recommendation?So, I run what the HEMI Ram Gurus recommend.
The GURUs are the ones that have spent hours of their day for the past 15 years tearing these 4th and 5th gen HEMI engines down and building them back up. Pushing them to the limits. Testing new fluids, parts, computer parameters, etc…Rebuilding wore out or modifying new engines for people, that don’t know how. The ones that I have bought my parts from and got my tuning needs taken care of, for the past 10years of owning Rams.Who are those and what engineering criteria they used for the recommendation?
There's another avenue that i think you should consider. They spec an oil that'll just make it past the warrenty period,then they keep supply and inventory low on replacement engines,so it's a 6 month or longer wait for a replacement engine,and viola they've created a customer who is now in the market for a new truck.As they can't wait for replacement parts,that don't really have a date for when they'll show up,so now they're between a rock and a hard place,and end up trading their vehicle off at a depreciated value,with a bad engine.They cover two stones at once,they keep the EPA happy and their Cafe window sticker numbers up for fuel consumption numbers,and they've created a customer who is pretty well stuck with trading their vehicle off at the same manufacture'r they purchased from,to get a semi decent return on their trade-in. Just my 02.I suspect Wild one is right with some of his reasons for why Ram went with a lower viscosity oil, but they aren't going to recommend something that they know causes engine failure.
Maybe, but how many people in that situation wouldn’t buy another Ram truck out of concern the next one might have the same problem. I know if I was in that situation I’d consider switching brands. I realize they all have their issues, but the Ram issue would be freshest in my mind. It would be a big factor in my buying decision.There's another avenue that i think you should consider. They spec an oil that'll just make it past the warrenty period,then they keep supply and inventory low on replacement engines,so it's a 6 month or longer wait for a replacement engine,and viola they've created a customer who is now in the market for a new truck.As they can't wait for replacement parts,that don't really have a date for when they'll show up,so now they're between a rock and a hard place,and end up trading their vehicle off at a depreciated value,with a bad engine.They cover two stones at once,they keep the EPA happy and their Cafe window sticker numbers up for fuel consumption numbers,and they've created a customer who is pretty well stuck with trading their vehicle off at the same manufacture'r they purchased from,to get a semi decent return on their trade-in. Just my 02.
Only time will tell how a 5.7 lives on 0W-20,but i won't be surprised if we start seeing more engine complaints once the trucks spec'd for 0W-20 and 10,000 mile oil change intervals,start getting a few miles on them
Sounds like my next oil change will be to 5W 30!There's another avenue that i think you should consider. They spec an oil that'll just make it past the warrenty period,then they keep supply and inventory low on replacement engines,so it's a 6 month or longer wait for a replacement engine,and viola they've created a customer who is now in the market for a new truck.As they can't wait for replacement parts,that don't really have a date for when they'll show up,so now they're between a rock and a hard place,and end up trading their vehicle off at a depreciated value,with a bad engine.They cover two stones at once,they keep the EPA happy and their Cafe window sticker numbers up for fuel consumption numbers,and they've created a customer who is pretty well stuck with trading their vehicle off at the same manufacture'r they purchased from,to get a semi decent return on their trade-in. Just my 02.
The only thing is a Ram with a sick engine isn't worth anything at GM / Ford or Toyota,so you're basically stuck back in a Ram if you want a decent trade in credit.Maybe, but how many people in that situation wouldn’t buy another Ram truck out of concern the next one might have the same problem. I know if I was in that situation I’d consider switching brands. I realize they all have their issues, but the Ram issue would be freshest in my mind. It would be a big factor in my buying decision.
That was one of the better parts of that movie,lol
