Just installed this today. Very easy and works great. The only strange thing is when I put the key in the ignition and turn it on, my low tire pressure light flashes on for a couple seconds then turn off. Otherwise the unit works great.
Will this kit work with 2017? Also, was a little disappointed when the title says Remote for under $100 and actual kit is over $200 CAD...
That's because when this thread was started back in 2012 it was under $100. It has since gone up as the technology has advanced.
I would contact the seller if they aren't explicit. Sometimes, they don't update the compatibility list because they are unsure if the manufacturer made a change.Makes sense. But 2017 ok?
"go away, I'm bait'n"Technology use to make things more simple and more cost effective ..............NOW technology makes things MORE DIFFICULT WITH MANY MORE POSSIBLE POINTS FOR FAILURE AND MUCH MORE EXPENSIVE FOR THE CONSUMER!
We are getting dumber every day!
Take my word for it , watch on Netflix = idiacracy
Our Journey did that from day 1. Other than that never had a problem.
The other thing I noticed is the clock on the radio resets to 1200 every time I start it. Hope this remote start doesn't fry my electrical system.
I need to reflash my dball on my 2012 1500. Anyone can help me out how i can get hold of login for directechs? I have an xloader but needs login for the site. My unit when i unplug it and plug it back, led will flash once then do nothing. Any suggestions? Thanks in advance
I just installed the 3XL (three times lock) remote start sold by "doug43235" on eBay that so many of you have mentioned. It went fairly smoothly. I would not call it easy, but certainly not hard. There were a few moments where I kind of had to figure it out as I went.
My kit included the Directechs 4x10/5x10 module, XKLODAER 2 programming tool, and Directed THCHC3 T-harness. Programming was fairly easy with the instructions that doug includes. Temporary login info for the directechs website was included.
Here's where I mounted the Remote Start Safety Override Switch:
Overall, I'm pretty happy with how things turned out. It works great!
I think for safety purposes. The factory remote start has a good latch safety to prevent the engine from remote starting while open.I just zip tied that switch up under the dash but am curious what the purpose of it is. It disables the start function i think, but why?
