68rfe filters and fluid
18 Longhorn
Tennessee
Cummins 6.7
I want to change my transmission fluid and filters. I have been doing some searching but i can seem to find the oem filters does anyone know where to get the fluids and the filters online or is there a better filter setup you recommend?
18 Longhorn
Tennessee
Cummins 6.7
mtnrider
Georgia
Where may I find an oem seal gasket for the trans pan? Or is there an equivalent in quality option
There is no gasket, they use sealant. I just bought the Mopar RTV/sealant they recommend but I'm sure any automotive grade gasket sealant will work.
buckeyexx
Ohio
2016 Power Wagon
Look at summit racing. They have the oem filters and gaskets as does Amazon. I have a felpro gasket on mine it has been leak free. A rubber gasket is reusable. The plus side to using a gasket you do not need to wait to refill your trans. The gasket maker needs a bit of time before filling and more of a mess.
buckeyexx
Ohio
2016 Power Wagon
Found the mopar one on Amazon thanks guys
Just make sure you get the correct sump filter as they differ from 4x4 and 4x2. The 4x4 has a longer tube on it.
18 Longhorn
Tennessee
Cummins 6.7
Does this gasket seem to be the right one for the 68rfe it doesn’t look like the same shape as the lube locker one. Edit: that is an oil pan gasket I found the trans pan gasket on racing summit site
18 Longhorn
Tennessee
Cummins 6.7
On Amazon the numbers end in ac and on summit racing the spin on ends in ad and the flat filter ends in ae is there a difference?
18 Longhorn
Tennessee
Cummins 6.7
The letters are just miss printed they are the same filters on both sites
buckeyexx
Ohio
2016 Power Wagon
Your filters look correct but that gasket is not. This is the one I ordered.
FEL-PRO TOS 18733 Automatic Transmission Gasket https://a.co/d/a5arVtN
06 Dodge
6.7L CTD
You need 68425659AA Genuine Mopar 68RFE transmission rubber coated metal pan gasket... Check with Benny from All Mopar Parts : https://www.ramforum.com/forums/all-mopar-parts.133/ he is a preferred vender here on Ram Forum and he sells Mopar parts at discount
18 Longhorn
Tennessee
Cummins 6.7
I ordered the lube locker gasket off of summit racing seems to be a good gasket from the reviews. Any experiences?
I prefer gasket maker, if done right it is simple and wont leak period. Guys use gaskets with good luck too, I think you can actually put gasket maker under the seal. The mani thing, avoid a leak because it is an incredible waste in this application. Get the metal thread upgrade, they have synthetic filter options for canister, only use mopar sump they are great. Redline c+ is a great fluid for the rfe. do yourself a favor and get the corect metal thread, stay away from billet ones they are loose, this one. To use gasket maker right you should let pan sit overnight before you fill.
