8 speed swap
Ryno1500
California
Hemi 5.7 eTorque
I think what he's saying is that you can use the stock dial shifter or swap it to a console shifter from a challenger/charger if you'd like to. I'm still convinced this is possible with a few lucky trips to some pick n pulls to get everything you need.
Did occur to me that there would also need to be the wiring for the dial/console shifter ran as well. I haven't seen anything that shows it's stock. I'm going to pull my radio bezel out far enough that I can look back there and see if I have those connectors or not. That would be a bit of tough pill to swallow if you had to pull the dash off to run the hook ups
From what I’m seeing, there’s a jumper cable that connects to the wiring harness behind the dash. Pretty sure it’s already there for my truck, since it’s a 4x4.
NOV87
PNW
Lot of good info here! Question: where do you guys mount the dial shifter? I have 4×4 switch in that spot and column shifter, not the floor one. 2014 4wd Express.
Ryno1500
California
Hemi 5.7 eTorque
You will pull your center bezel and replace the transfer case dial with a combo switch.
NOV87
PNW
Oh, the combo shifter has both, go figure
Now, I know. Thank you!
t0ymach1n3
Oklahoma
5.7L???
I've got a friend that currently has a 13 and has managed to move the shifter to the console. So it could be possible to maybe reroute that switch?
I know my weekends will be spent at pick n pulls and online to shrink my list of parts needed to get this done! I am really excited at the prospect of an all OEM 8 speed swap.
Ryno1500
California
Hemi 5.7 eTorque
Nice! I'm still debating, do I dive in or pull the trigger on a new truck.
t0ymach1n3
Oklahoma
5.7L???
I did for a bit before deciding for the swap. My truck is paid for, I would end up paying about the same amount to do the swap and power upgrades as I would for a new or decent used truck. The biggest for me is Ram doesn't make the RCSB anymore. I just couldn't bring myself to do it lol
TheEnder
4.7L V8
You might be the first with the 4.7 to do the swap!
It made the 5.7 much more competent; and the 4.7
Man, that's a lot of Xs.
I'm happy people are using it, that's why I posted it. No credit needed.
Hey again,
I checked my PCM connectors today and the connectors on mine are brown. I read up somewhere (excuse me if i'm quoting the wrong person) that if you have brown connectors your vehicle is already equipped with what's needed to handle the 8spd?
Ryno1500
California
Hemi 5.7 eTorque
Hey again,
That’s the story I’m hearing. I have the white connectors, so I have to do a ECU swap and have someone tell me how to reprogram the vin.
emjohn4
Hey again,
Since I don't have a 2014+, I can only use some background experience to speculate and make some assumptions.
If you pull the dash console, and can find an 8-pin connector that is unused near where the rotary shifter is located; that likely means your dash harness is ready. Then, if you are able to go under the truck, and find a large round connector near the transmission taped to a wiring harness, you're PCM harness is likely ready.
If you don't have those connectors, then I would assume (key word....assume), that you would need to source the right harnesses, and then just plug them into the brown connector on your PCM.
Then, I assume (another key word...assume), you would need to use HP Tuners to activate the 8HP70 option in your PCM and deactivate the 65RFE option. Its a simple dropdown selection - I could show you what it looks like in a 2012 if you want via screenshot. I'd assume (key word again) that it would be the same in a 2014.
Sorry I can't help more, the whole 2014+ Brown/White plug is beyond my experience.
t0ymach1n3
Oklahoma
5.7L???
Hey again,
That's what i'm gathering as well. The brown connector came with 8 speed optioned trucks.
t0ymach1n3
Oklahoma
5.7L???
This is what I have. Is this "brown"?
Sorry, I might be color blind
That's the 6 speed ECM. The brown one(8 speed) looks like this. Wasn't too difficult to find one (Got mine last night on eBay for around $100 shipped). The wiring harness for the engine/trans.... that's a different story lol
Ryno1500
California
Hemi 5.7 eTorque
I just looked at my wiring, I only have the transfer case plug, so I would have to change the jumper wiring. Though, I may take the easy way out and take my dad’s 2018 Big Horn and then sell this one.
RAMTRPR
"Enjoy The Little Things"
Brentwood, CA
I have ordered most of the parts for my 8spd swap, but had a question on the cooler lines. Is it easier to cut and make your own from the current trans cooler or buy the 8spd truck lines to try and hook up to the trans?
Also I am a 4wd 2009 so I think my Transfer case is a NV243. I was told I may have to switch to a BW 44-45 to get my 3wd to work. Any help on that?
BTW thanks for the parts list and all the info in this thread.
emjohn4
I'd suspect, but not guarantee, the bolt pattern on the NV243 is the same as the BW 44-45. You could do an interchange search for the 54RFE gearbox for a 4x4; and if it interchanges from 2009 to 2012+; then you should be OK.
Most seem to think it is easier to cut your transmission lines from the RFE trans and patch them to the 8HP70. I think it was easier...but YMMV and all that.
J
jmihalchik
if you were to swap the lines complete you would also need a new AC condenser that the trans cooler is built in with the condenser.... all the lines as well as the oil heater that attaches to the side of the trans.... This would leave the cooling ports open (not a big deal).... i have no cooling issues at all, in fact usually too cold (hence why ram put a heater on this trans for the pickups)... if you were to swap it would really just make the setup look more OEM.
RAMTRPR
Brentwood, CA
Yeah my cooler now is built into the AC condenser. I am going to have my lines cut and flared then add lines back to the trans. Hopefully I don't have too cold issues. Don't ever drive the truck crazy when its cold and I'm in California so it never gets "really" cold. :)
You could plumb one of these into the lines,if you think it runs too cold.CrazyKid is doing one of these,but i'm not sure if he's got it installed yet or not
smoothee
St. John's, NL
I think that's the route I'm going to go too, not sure on the 145 or 165 yet though
noraa73
