AlfaOBD
magician
So without having to go thru all 900+ posts what setup do I need for my 2015 CC w/8spd?
SitKneelBend
Moderator
Member Relations Specialist
St. Louis
3.6 Pentastar
While playing around with compass settings I found the heading doesn't change after making changes until you begin to drive.
In addition, the navigation on a RA4/VP4 appears to be thrown off by the compass orientation setting being set incorrectly. "Right side up" was the right setting for me with a homelink module mounted in the overhead console.
Fisher99
NE Oregon
Cummins 6.7
I've looked through the docs on post #1 but am not seeing anything about disabling the "Lawyer Screen" that requires you to press "Accept" or wait for the screen to time out. Is this possible to do with AlphaOBD for my 2013 Ram 2500 Laramie?
Jchaak
Wa
You need to purchase a Smart Beam (Auto High Beam) mirror. If your truck currently has a microphone mirror your harness with be correct. You will also need to enable the codes with the alfa tool. Be careful when purchasing the Smart Beam mirror if you purchase it from Ebay or a wrecking yard. They are listed incorrectly all the time. The Smart beam is only an option on the Laramie and higher trim levels. It is standard on the Longhorn and Limited. It is available on the standard Laramie but is not standard. It's part of the group 32 option package. The smart beam mirror will have the camera looking device on the back if the mirror like the one in the pictureab845624b5227c772aaf90886fd6f1cc.jpg
What is auto dim electric eye in the photo for?
Ricks Ram
The small square auto dim electric eye on the mirror body itself is to determine the amount of ambient outside light for the auto dim mirror to activate. The camera looking lens in the actual base of the mirror is for the auto high beam to determine incoming headlights to tell your truck to dim it's lights when it has the Smart Beam option.
Ricks Ram
There is no setting that I am aware if in the alfa tool to disable the press to accept soft key on the radio.
Jimmy07
Hey Rick, Did you ever get a word back about the "Power Converter Present" option for 2017 on Alfa?
There is a way to force the ECU 3 setting, but you need the windows version. You would connect to a 2014 BCM in advanced mode, and this will populate that setting in the ECU 3 list to enable.
big daddys house
Hill Valley
If by setup you mean, what tools are required to make the changes, then this is an easy follow along video for you. Page 1 in this thread also has all necessary links to get started.
Sent from my LG-LS995 using Tapatalk
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
Is this the same for other settings too? When I look at my original backup file I see some settings (like "remote compass present") that I can't see to set in the car configuration change list.
Jimmy07
It’s possible for some other settings. Where is the remote compass present showing up under (ECU 3, VehConfig 1, etc)? I don’t see that one in my BCM configuration list, but if I knew where it’s “supposed to be listed”, I can check into it.
Fisher99
NE Oregon
Cummins 6.7
Thanks for the confirmation. I spent an hour or so going through the menus yesterday afternoon and didn't find anything either.
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
Here you go. It's in the first section of settings on mine under ECU Qualifications. When I connect with Alfa I use the 2013-2017 Powernet option, should I try 2014?
Vehicle Configuration Programmed Status: Yes
Last Programmed Status: Service
ECU Qualification:
Sense-Ambient Light Dimmer Wheel: No
Sense-Reverse Switch: No
Sense-Door Lock Switch Front Driver: Yes
Sense-Door Lock Switch Front Passenger: Yes
Sense-ERS Switch: No
Sense-Flipper Glass Ajar: No
Sense-Fuel Level Sensor #2: No
Sense-Hood Ajar Switch: No
Sense-Hard Top/Stealth Input: No
Sense-Liftgate/Trunk Ajar: No
Sense-Trunk/Flipper Glass Release Switch: No
Sense-Rear Wiper Park Switch: No
Sense-Washer Fluid Level: Yes
Sense-Flipper Glass Release/Sunshade Switch: Yes
Sense-ESP Off Switch: Yes
Sense-Cargo Lamp Switch: Yes
Police Passenger Unlock Motor Present: No
Control-Headlamp Leveling: No
Control-Baggage Comp Lamps: Yes
Control-Diesel Cabin Heaters 1-3: No
Control-ESCL: No
Control-Diesel Fuel Heater Relay: No
Control-Flipper Glass #2: No
Control-Foot Well Lamps: Yes
Control-Front Fog Lamps: Yes
Control-Headlamp Washer Motor: No
Control-Passenger Airbag Off LED: No
Control-Rear Fog Lamps: No
Control-Rear Turn Lamps: No
Control-Rear Wiper Motor/Flipper Glass #1: No
Control-Run/ACC Relay #2: Yes
Control-Side Repeaters: No
Control-Sunshade: No
Control-Trunk/Flipper Glass Relay: No
Control-UGDO Feed: No
Control-Trailer Tow: Yes
Control-Dedicated DRL: No
Control-VTA Indicator Request: Yes
Control-Passenger Airbag LED: No
Adjustable Pedals Present (Non-memory): No
Inverter Present: No
Intrusion System Present: No
Remote Start Present: No
Tip Start Present: Yes
HID Headlamps Present: No
Auto Headlamps Present: Yes
Rain Sensor Present: No
Remote Compass Present: No
EC Mirror Present: No
Cruise Feature Present: Yes
RKE System Present: Yes
SKIM System Present: Yes
Police Vehicle: No
Military Lighting: No
AC Present: Yes
Rear Doors Present: Yes
Electronic Shifter Power Feed Present: Yes
Jimmy07
ECU Qualification:
Control-ESCL: No
Police Vehicle: No
AC Present: Yes
I believe those are just qualifications, or, the state that those features are in while the BCM is being read. It doesn’t necessarily mean that the compass module isn’t installed and enabled, but that the BCM is not getting a reading from it at that time. Is your compass heading showing just dashes when you read the system status?
Ramshig
HEMI 5.7
Is it normal for your odometer and your BCM mileage not to match. I just did the 7in swap drove about 2200 miles and now my odometer is reading about 150 more miles then my BCM. Just wondering not a huge deal.
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
I'm not sure what you mean by reading the system status, but when I install a newer UAS radio the compass reads "--" in the EVIC. If I remove the radio completely or reinstall an older 8.4 RA4 radio it shows just fine.
Does that tell you anything?
Jimmy07
Reading the system status (or ID) is what you did to come up with those ECU qualifications.
I’m not sure why yours behaves that way, but here’s what mine are set at for everything (I think) that has to do with the compass. This is a 2017 that has a swapped in 7” EVIC, UAQ radio, and overhead console with homelink.
VehConfig 3 display compass heading present- yes
LIN and misc compass mounting orientation- upside down
LIN and misc EOM present- yes
LIN and misc compass mounting angle- 0 degrees
CustSetMenu 1 compass calibration CSM- yes
TacomaRam13
Tacoma, Wa
Gotta say I am really impressed with this AlfaOBD /OBDLinkMX and what it can do. So far I have done the fog light drop out, global windows down, HID turned on, changed heated seat material type, led fog lights and I think that's it so far. Each thing was done one at a time and worked right away without issues. Was gonna mess around with splash screen but mine already splashes SPORT on start up so didn't want to fool around with any of those settings. I do want to figure out the threshold value for auto headlights but I don't know what the current baseline setting is so not sure what value makes headlights come on later. The last thing I want to figure out is if I can change the remote start values to allow more fob starts before having to start the truck with the key.
I asked about this before. I think somewhere in here one person has said they changed theirs, but I'm not sure which on the two settings they changed. I want to do it, but haven't messed with it yet. Maybe someone else will chime in and say which one they changed and to what value.
Ram7081
Hurricane 3.0
I used AlphaOBD on wife's Durango. Everything worked I did (remote for windows, alarm, fogs with high beam, etc) but the LEDs for headlights don't. They flicker. On Ram its fine. Durango, no go. Thoughts?
1500ram12
5.9L Cummins
Leave led low's off turn on VehConfig 3 high intensity discharge lights
2018 Ram 2500 6.4L Hemi Tradesman
alphaprojects
