Roman217
- Joined
- Apr 13, 2018
- Posts
- 366
- Reaction score
- 342
- Location
- Metro Detroit, MI
- Ram Year
- 2015
- Engine
- 5.7
@justinkyleo Don't get too discouraged yet! So you have looked at your first config you pulled when connecting to Alfa and the most recent one from yesterday or whenever you made the change? If you have and went line by line comparing, then you had to of missed something. Trust me, it is extremely easy to do. I still have double vision looking through mine from the past couple days.
You could also try pulling the positive and negative battery cables off and letting the truck sit for more than 20 minutes. Then reconnect and let everything come back.
After RAM flashed my BCM I used Notedpad++ with the compare plugin to check the config line by line. From the main log just copy each set of configs into a separate file in Notepad++ then drag one of the tabs to the side to "open in other view." Then use the compare plug in and it will give you all the differences line by line.
