AlfaOBD
Ghost_RAM
Ghost_RAM
VA
I had a right front turn signal bulb burnout. It put my entire turn signal system down except for the left front bulb - I thought that was strange. It also put my emergency flasher system down. I replaced the burned out right front bulb and all was restored except both rear tail lights would not light as a turn signal or an emergency signal The stop lights work fine with the lights on or off and the tail lights work with the lights on
I ran AlfaOBD diagnostics and there are no codes. However, the log has a listing:
ECU Qualification:
Control-Rear Turn Lamps: No
My dilemma is I cannot find how to change them to "on". I have been through all the items three times and they all seem to be set properly.
Any ideas what setting caused the log to report the rear turn lamps "no"?
"Control-Rear Turn Lamps: No" should be set to no. Start reading around here and see if it helps.
https://www.ramforum.com/posts/1830993/
John Jensen
San Diego County
Ecodiesel
Thanks Ghost,
That is reassuring that I have the correct settings. So if all my settings are correct it must be something mechanical or physical. Guess I need to visit my favorite Service Manager
FXCLM5
2017 Laramie CC
ED 3.0 V6
omg your kidding me, last time this thread was in the 90-100 page, now its 170+
ugh, i need a cliff notes
FXCLM5
2017 Laramie CC
ED 3.0 V6
A quick note for anyone else having trouble getting a System Status on the Driver Door Module and further praise for the author. After having @Ricks Ram confirm that it wasn't just my truck that wasn't giving a system status for the module readout I sent the error off to the author along with the usual debug file and examples. He had the bug located, fixed and a patched copy for me to try in less than 6 hours. I just tried it and the Driver Door Module System Status now works correctly. The fix will be in the next general release.
-K
Dang wished the developer would just answer my email....
stimpy433
IOWA
Wow that is actually pretty strange. Do you have the option to turn the feature on and off in your settings menue? I have done several of the conversions and I haven't seen this happen. It either is on or it's off. Since his 3.5" speedometer displayed the image correctly it's got to be some type of glitch with the new speedometer.
I ran thru all the setting last night and I don't have an option to turn on/off the turn by turn anywhere....
Ricks Ram
Do you mean you ran through it all with the alpha tool to see if it's in your BCM or you ran through the settings menu on the radio? If you looking with the alpha tool it will not show up unless your actually plugged into your truck and connected to the BCM. It will be in the BCM configuration change section towards the bottom in the CSM settings section. If you are just looking for the setting in your radio it would be in the navigation settings menu. If you have a newer radio with newer firmware it most likely wont be there unless you have enabled the code in the BCM.
stimpy433
IOWA
No, alpha tool yet, just looking thru the settings on the radio itself. I need to get it so I can add a few things. I take it that option isn't on my radio then which is my factory 2014 RA3 with the newest firmware.
Ricks Ram
No it wont be there after with the newer firmware untill you enable the code in your BCM and then it should show up.
dav8388
Summerville, SC
In limbo between trucks
3.6 pentastar
I just got the compass module working.
Show compass heading
Select yes
Compass mounting orientation
Select right side up
EOM presant
Select yes
Compass variance
Select yes
Compass calibration
Select yes
Ricks Ram
Select yes
EOM presant
Select yes
Compass variance
Select yes
Compass calibration
Select yes
That's great to hear! I think your the first one who has actually installed the compass and used the tool to set the codes. The next thing to try might be for someone whose truck came with the RA1 radio with no overhead console to install the Homelink and wiring and see if we can figure that one out as well.
likes2build
Mohawk Valley, NY
2018 Express RCSB
3.6 Pentastar
I'll be doing that as soon as Deereguy gets back from vacation and gets caught up. He's making a few of us a plug and play overhead console harness. I already went it to the Alfaobd and turned the compass setting on and I know for a fact that it works as it added a -- mark just to the left of my outside temp on the small EVIC
dav8388
Summerville, SC
3.6 pentastar
My truck originally had a UA1 and no overhead console. i put a homelink module in my 95 Intrepid a few years back and IIRC all it neede was a power and ground, so i would think these would be no different.
I just went for a drive, and after driving in a circle to get it calabrated it works perfect siting on he steering column in front of the gauges. I was planning on making a longer harness, and sticking it inside the headliner cause I dont plan on using the stock overhead console. Now I think ill mount it in the dash behind the guages and see how it works.
Ricks Ram
It will need the code enabled in order for the commands to show up on the EVIC. I know in the factory configuration it will not work unless the code is enabled. I guess it may work if you just wire it to hot and ground without adding the codes and it just wont show transmitting or training in the EVIC. The module itself has three pins. I'm assuming one ground one hot and the other for the CAN/BCM. I'm not sure if it would be able to illuminate it at night. Not sure if anyone had tryed just hotwiring it in. I'm curious to see how it were works for you. Let us know how it goes.
dav8388
Summerville, SC
3.6 pentastar
It will need the code enabled in order for the commands to show up on the EVIC. I know in the factory configuration it we'd I'll not work unless the code is enabled. I guess it may work if you just wire it to hot and ground without adding the codes and it just wont show transmitting or training in the EVIC. The module itself has three pins. I'm assuming one ground one hot and the other for the CAN/BCM. I'm not sure if you would be able to illuminate it at night. Not sure if anyone had tryed just hotwiring it in. I'm curious to see how it were works for you. Let us know how it goes.
Oh ok. I didn't realize it displayed anything in the EVIC. If I can get a homelink one Ill try it. I like a challenge.
Ricks Ram
I'm hoping you do. My truck came with the overhead so I installed the homelink plug and play. I know alot of guys have been interested in doing it but I don't know of anyone who has actually done it now that we have the alpha tool. I did do one in my friends truck but we had a doner harness so it was pretty strait forward.
78Staff
US Navy Veteran
NE Florida
Power Folds are installed with new switch and modules, it actually went pretty fast. But, I'm not completely there yet. I updated the following entries per the Google Doc:
Puddle Lamp Present
Select “yes”
Mirror Turn Signal Present
Select “yes”
Electro-chromatic driver mirror present
Select “yes”
Electro-chromatic passenger mirror present
Select “yes”
Driver Memory Mirrors Present
Select "Yes"
Passenger Memory Mirrors Present
Select "Yes"
Tilt mirror in reverse
Select "Yes"
Got the CSM settings showing, but when I try to select them, they check and then uncheck - so maybe I haven't waited long enough? Is adding power fold mirrors one of the ones that takes longer than normal? All other window functions are working, mirror turn signals are working - not sure about puddle yet though. I know I read something in the thread about settings unchecking I'll have to search back.
I didn't see any specific "Power Folds Mirrors exist" type entry - there was a "Folding Mirrors Present" entry that was not set, so I set it to yes.
Anyway, it's sleeping now going to give it some more time...
Ricks Ram
Puddle Lamp Present
Select “yes”
Select “yes”
Select “yes”
Select “yes”
Select "Yes"
Select "Yes"
Select "Yes"
My 2014 did the same thing. When I enabled the tilt in reverse it wouldn't stay checked on the screen. It went through several sleep cycles and never would work. I finally took it out. Everything else works fine.
78Staff
US Navy Veteran
NE Florida
Well dang TIR is one of the main reasons I went with the premium mirrors. The power fold part isn't working either yet, I'm letting it sleep some more
Ricks Ram
I have done the power fold on another truck with the tool and worked fine. It was a 15. That being said it's hard to say what will actually end up working. I enabled the tilt in reverse on a different 14 and it worked fine so I'm not really sure what was causing mine not to work. I set it and removed three different times and also tryed enabling the codes in different orders and nothing helped.
