AlfaOBD
LT Tolbert
Alabama
I just purchased the alfa obd app and the OBD link mx. Is there a way to get srt graphics and performance pages loaded onto the infotainment center?
2016 Laramie
Eng50
Richmond, Va
Cummins 6.6l
2016 Laramie
Pretty certain there is and it's been talked about in this thread..I just don't know where off hand...I'm sure a search will get it, this thread is huge!
Sent from my ONEPLUS A6013 using Tapatalk
1500ram12
5.9L Cummins
2016 Laramie
Look at post 1. Has instructions for everything that has been done so far
1500ram12
5.9L Cummins
Sorry for being the rookie lol I have never used a forum.
Sorry didn't mean for that to come off *******. There is a lot of info in post 1. I spent days reading through this thread a couple of months ago. Most of the bigger threads on how to add things all the steps and info gets put in the first post to kind of organize it
LT Tolbert
Alabama
I read the list and did what it said but the changes didnt go through to the truck for some reason. I did the set logo on startup. Alpha obd said it did it, but no changes showed up
1500ram12
5.9L Cummins
Each truck is different. Let it sit for 15 minutes and check again. Give it a couple of key cycles. You may have to try it again for it to take.
diboblo
California
Also, you can check status by clicking START once, on each setting. The dialogue box will indicate the trucks status and verify if the programmed condition was set.
Like many have said, the vehicle needs to "sleep", before settings will take place.
My DRL changes took 24 hours to set.
Bob
Onethatislazy
US
Ram 1500 fob baseline programming is fixed with the newest version 2.1.6.8. :). Tested and verified with my cheap Amazon key (keyless entry key not remote start key) in my prior post a ways back.
Too bad the erase wasn't there before I got 4 remotes programmed. :). Guess my used car will have a 5th remote wandering around somewhere unknown.
Sent from my SM-G975U using Tapatalk
Tankerpilot01
Lawson, MO
Cummins
Bob
I have to try again on my DRLs. Didn’t take. Using the procedures for the projection factory lights. Hoping second time is the charm!
JB1
Houston, Texas
You can try to change one setting at a time and let it sleep between each change, that's what I do and I have never had an issue.
Tankerpilot01
Lawson, MO
Cummins
Good call. In long run probably faster...slow is fast. How long do you let it sleep?
1500ram12
5.9L Cummins
I usually will turn the key to the off position then open the door, you'll hear things slowly start shutting down, usually takes a minute or two, then will proceed with the next step
Tankerpilot01
Lawson, MO
Cummins
Oh good to know! Not long. I was afraid you were going to say over might lol thx!
Cheers [emoji482]
Redheadhunter21
SFL
The auto dim and even memory mirrors will work with the non power fold door modules. The only difference in the power fold door modules that we have been able to find is the power fold function itself. It seems odd that they would make a completely different module just to add one feature but it appears that's what they did.
There are more pins populated for the power folding modules, that's the only noticeable difference from the outside. Its probably just a numbers game at this point, and they didn't have power fold for a couple years in the start
2016 Laramie
If you get the SRT/Performance pages to work ,make sure you post how you did it,i'd like these on my 14 Sport with the 8.4 Nav as well.My wifes 16 Challenger has them,and they are pretty damn cool to have,lol.Might be worth starting a separate thread,this one is getting way to long to keep up with.
mjf6175
NJ
cummins
The SRT Performance pages have been attempted in the
There isn't a RAM based SRT page in the radio. Enabling the performance pages and "vehicle is an SRT" will only change your 8.4 splash screen to say SRT, the performance pages just won't do anything. For more info see posts #632-636 in this thread, link below:
https://www.ramforum.com/threads/alfaobd.123982/page-64
You used to be able to Jail Break them,i have a buddy who did it on his 15 Sport,but i'm not sure if you can still jail break them now though.Kind of kicking my ass I didn't buy the same program as he did a few years ago,when they were still cheap,lol.
Ghost_RAM
Ghost_RAM
VA
From what I understand once the radios went over 17.XX the Customtronix method as well as the jail break ceased to work. Only a side load method will work now if/when someone comes out with it. I thought Tazer was looking into it but I'm not sure.
TMFMK
