AlfaOBD
Psyko Sematic
Oklahoma
Not sure if this was discussed yet but I was able to clear the error message for LED reverse and license plate lights through Alpha OBD without installing resistors.
You’re lucky . My parking light out error still shows up in the cluster but the actual error on ALPHA OBD is B16BF . Which is a front left side marker lamp error . Not even sure what that is lol
diboblo
California
AFAIK in motion navigation is not possible through alfaobd... Not sure if there are other ways to do it.
Sent from my Nexus 6P using Tapatalk
Browsing the Audio menu, I get to
RADIO TELEMATIC GATEWAY
Then,
IN MOTION MENU CONTROL
Then,
OVERRIDE OCCUPANT INFORMATION
with the option to enable, or disable.
Has anyone tried to modify this setting, to get Nav In-Motion?
Bob
Ricks Ram
Yesterday I installed a CHSML camera in place of my third brake light....I have not activated it yet . I am getting a message on the evic that the R brake light is out. It is working. Is there a way to clear this with alphaobd? Thanks
Go into CBC features and select LED-CHMSL lamp present. b2b2e68b07f35f5e9cd1ea2249c131dc.jpg
rt395
Huntington Beach
Straight Six
On the very first page of this thread there are simple instructions on how to make a backup using AlfaOBD. It seems prudent to do so before modifying the truck in any way so I followed the steps and the alfaobd app popped a message indicating that I had successfully uploaded the backup to my google drive. Problem is the file is a blank file - nothing in it at all.
Have you all checked to see what your backup file looks like? I've tried twice now with the same result.
diboblo
California
Sometimes, you need to tap the battery icon, to force Alfa to read the BCM. Then you can follow the instructions and it will upload properly.
Bob
Lawsuit11
Westland, MI
Then,
Then,
Bob
That could be a possibility
Canada
Then,
Then,
Bob
Where did you select the first picture to get to that I’ve been looking for this but never find it what is the audio section
chrisbh17
It’s Radio. Option right about RF hub
Not sure if it shows up once a nav radio is installed, but I dont have most of the options in the Radio/Nav drop down.
Then,
Then,
Bob
My Control Unit dropdown values are different than yours, I do not have the Telematics gateway.
Do you know what version of the app you are using?
Psyko Sematic
Oklahoma
I put in some retrofitted headlights with switchbacks and halos and DRLS . And since mine wasn’t a LED version I am getting a left side marker lamp control our error .
So updated - I took my left headlight out and can’t find anything unplugged . still getting the “ parking light out “ on the cluster and the Alfa obd says it’s code B16BF which is left sidemarker lamp control short circuit to + battery/open circuit . Still no idea wtf that is lol
chrisbh17
What headlights? I have a small issue with my modified aftermarket ones, depending on certain circumstances.
And just because you may have corrected the issue does not automatically clear the error. You have to go through the process with AlfaOBD of clearing the confirmed faults.
diboblo
California
2.1.7.3
Bob
Psyko Sematic
Oklahoma
I have OEM black sport housings with MORIMOTO D2s 5.0 , diode halos and switchbacks .
Canada
Strange, me too.
I have tried looking everywhere and nothing can’t access anything that turns off Mac in motion I’ve emailed DEV. everyone should be may make this accessible
rt395
Huntington Beach
Straight Six
Bob
Thanks! that makes sense now that you say it but I hadn't thought of it...
ImaginThat
Washington
Turn on the parking lights, look to the outside of headlamps you should have a amber light in the corner hence the side marker light :)
KAKA
