TJP440
Email the file to yourself and open the file using Microsoft Outlook. It reads the file just fine. Don't ask me why, I just know it works. (It shows it as opening within Outlook using Notepad)
Small part of what the file looks like when I open the attachment from an email inside Microsoft Outlook.
2023/05/04 11:36:51.734
VIN - Current: **************0678
VIN - Original: *************0678
Ecu Serial Number:
ECU Serial Number Data Identifier: T
ECU Serial Number Supplier Option: 1C
ECU Serial Number Component Code: 16
ECU Serial Number Day of Year: 312
ECU Serial Number Calendar Year: 5
ECU Serial Number Sequence Number:
ECU Part Number: 68482884AD
Hardware number: 68482884AD
Hardware Supplier Identification: Continental
Software Logical Block Supplier Identification: Continental
Active Diagnostic Status Of ECU: Running in Application mode
Gateway: Yes
Vehicle Configuration Programmed Status: Yes
Last Programmed Status: Manufacturing
After Market ECM Detected: Default
ECU Qualification:
Sense-Ambient Light Dimmer Wheel: Yes
Sense-Reverse Switch: No
Sense-Door Lock Switch Front Driver: Yes
Sense-Door Lock Switch Front Passenger: Yes
Sense-ERS Switch: Yes
Sense-Flipper Glass Ajar: No
Sense-Fuel Level Sensor #2: No
Sense-Hood Ajar Switch: Yes
Sense-Hard Top/Stealth Input: No
Sense-Liftgate/Trunk Ajar: No
Sense-Trunk/Flipper Glass Release Switch: Yes
Sense-Rear Wiper Park Switch: Yes
Sense-Washer Fluid Level: Yes
Sense-Flipper Glass Release/Sunshade Switch: Yes
Sense-ESP Off Switch: Yes
Sense-Cargo Lamp Switch: Yes
Police Passenger Unlock Motor Present: No
Control-Headlamp Leveling: No
Control-Baggage Comp Lamps: Yes
Control-Diesel Cabin Heaters 1-3: No
Control-ESCL: No
Control-Diesel Fuel Heater Relay: No
Control-Flipper Glass #2: No
Control-Foot Well Lamps: Yes
Control-Front Fog Lamps: Yes
Control-Headlamp Washer Motor: Yes
Control-Passenger Airbag Off LED: No
