Jimmy07
- Joined
- Feb 23, 2017
- Posts
- 3,257
- Reaction score
- 2,918
- Ram Year
- 2017
- Engine
- 6.4 Hemi
Ok...here are the differences in DOT and ECE beam patterns for headlight projectors-L
LEt me try to straighten that out. My factory headlights, country of origin and destination : USA, are the lights with the problem. Because the failed to move the beam impact point back 5-8' ish? So that if I'm going to blind the driver in oncoming traffic with poorly adjusted lights, this will happen 5-8' later? Because there is a notch that only cuts off the top of the beam at a certain distance before the entire beam is cut off by the 100% side to side metal "flap" that is also in the OEM projectors that do not do this. Probably because cutting the distance will not change the angle. I can blind the world if I want because some genius doesn't know that the form of lifht emitted from a projector scatters and is not a lazer and will not be directed, only cut off completely. And this decision to cut my capacity to see the left side, signage, etc was made my every aftermarket retailer? That boast OEM specs?
Please reference the 2013 and 15 ram sports below and know im positive im correct when I say "that is absolutely not true"
PS I apologize for the sarcasm prior to that. But where you introduce logic to explain a bad assembly, I feel obligated to poke holes in that line of thinking
ZERO beam retardation on all 3 trucks projectors.....hmm.
Any DOT compliant projector you buy will have a cutoff shield between the bulb and the inside off the projector lens with that stepdown pattern that is projected onto the ground in front of you-
In that picture, the projectors are aimed just a little too low, so you would insert a screwdriver (or socket, depending on which housings you have) into the headlight adjustment holes on top of the fenders, and start turning one way or the other to raise the projector up and extend the beam pattern further down the road. Either way, for the way you have those projectors adjusted in the housings for that pic, that red line I have drawn is 100% normal for projectors, and will be exactly the same if you buy a different set of projectors and adjust them to the same height you have pictured.
The projectors in the pic below are adjusted a little too high, so, obviously, the beam pattern is not projected onto the road in front of you to be able to see the steps-
Also, the stepdown on projectors on the left side for LHD DOT compliance is absolutely designed to reduce glare for oncoming traffic.
