AlphaRex headlight non support
1500ram12
5.9L Cummins
They were facing 9 to 3 then I changed them to 12 to 6.
I think the alpharex must use better projectors
Sent from my SM-G975U1 using Tapatalk
What led's are you using?
2018 2500 6.4L Hemi Tradesman
Mbrigh3
IG: Stormtrooper_5.7
MD
Hikara ultra led 12000lm
I've seen what the alpharex beam looks like compared to mine and its just crazy lol.
I'm about to take these off and order the alpharex gas. [emoji2369]
Mine looks like Swiss cheese
Riverside California
2018 2wd
HEMI 5.7 Revolution 4.88s
I’ve been in talks with a tech who said he was going to get me some load resistors. He sent me tracking info, however the tracking shows as “preparing for shipment” for the last 9 days so far. And no one is responding to my messages now. So time will tell how things go but currently not to impressed.
They are idiots .... my order was in process for 3 days with a system error which they admitted ... good luck ... I am thinking of sending mine back ...
1500ram12
5.9L Cummins
Yeah yours looks like quads with crappy led's in them. Weird that they'd are so bad.
Mbrigh3
MD
I'll keep you posted if leds fix the problem. Hoping them do but we'll see! The headlights are currently open on my ram so I can adjust them once it gets dark to see if that helps
1500ram12
5.9L Cummins
Led's are designed to be in the 9/3 o'clock position. I'd throw the halogen bulbs back in and see what the pattern looks like. If it's the same then you know that they are junk for sure.
Mbrigh3
MD
Its identical. Junk it is then
Mbrigh3
MD
I ordered the alpharex jet black version and ill throw leds into those instead. Should be here next week. Until then quads
XXSNOTRODXX
MI
Finally got back in touch with alpharex about still not receiving my resistors in the mail . They blamed the post office and said it’s due to the election....... ? Lol. Even though that shipment status never changed from “label created, preparing to ship”. Anyways..... they gave me another tracking number and promised this set is on the way. We shall see I suppose
Snowblind
Detroit
I'm installing the Alpharex pro series 5th gen 2500 style tomorrow and hoping not to jump through too many hoops with error codes, my truck is a 2014 so hopefully it's not too temperamental.... and defiantly not looking forward to contacting them for anything, took since labor day weekend to get the lights.
XXSNOTRODXX
MI
I love the lights themselves and the quality still seems pretty nice after owning them for a month. Only issue I have is the error messages and customer service needs work. But I know that I can get the error issue fixed... just waiting on parts to arrive. Best of luck on yours, hopefully you are one of the lucky ones that are error free.
XXSNOTRODXX
MI
Also a heads up for anyone, they have you tap into F66 fuse For daytime runners ...which works. But the issue is that it powers the lights up on accessory rather than in the run circuit.
So if you are for example at a drive in movie or want to sit with your radio on in a parking lot At a fast food joint.... you can’t do so without you lights on and draining you battery and annoying people around you.
On my truck I don’t have heated seats so I moved my fuse tap to that location which is a 12+v key on RUN circuit. They still function as daytime runners but now only while the engine is running (which is pretty much when you want them on Anyways right? Lol).
There are other fuses that can be used . Your location may vary depending on your options. Which you could still technically tap into since it’s not a big electrical draw .... I just personally like using a unused circuit.
Best way is to use a test light or multimeter and with the key in the ACC position check the fuses and recall which ones are showing no voltage. Then turn the key to run and recheck and see which fuses are now getting voltage and that will tell you what ones are on the run circuit and potential candidates to tap into.
Hope that helps.
Jimmy07
Hope that helps.
Suitable run only fuses for the behavior you describe for the DRL fuse tap: F85, F95, F96, F97, F98 on 2013-2018 Rams.
Dwight James
Can you tell me how your getting that error message fixed. I’m having the same issue
XXSNOTRODXX
MI
I believe I described it further back in the thread. I was able to install a led bulb on the parking lamp circuit which was just enough load to trick the computer into thinking it was back within halogen load values. I was in touch with alpharex tech support during all this and feeding them info as I made my findings and they matched up some appropriate replacment resistors that will take place of the resistors that they install in their headlights from the factory.
Some people have errors.... some don’t. Either way, enough have the issue that alpharex should be installing these beefier load resistors from the get go in my opinion.
2018 2wd
Dude .... they are a complete mess when it comes to processing and shipping ... it honestly took 2 weeks for me to get mine ...
I was going to order them the Sunday before labor day ... they told me they would be going on sale for labor day and should wait and as long as I ordered that Sunday they would have them ready for me to pick up Monday in the afternoon .....it took them til Wednesday afternoon to process my order and then they didn't ship it out til Thursday according to FedEx lol....
I think I might send them back and spend $650 on someone who deserves it because these idiots don't ....
Sent from my SM-T387V using Tapatalk
FLYxxBOY
Ohio
I just got my alpha black luxxs installed and I love them. No error or light out codes either (2016). I ordered labor day weekend and had them that Friday. I might use a different fuse tap too because I was chilling in the parking lot listening to the radio and thinking man I wish I could turn my drls off lol. @XXSNOTRODXX when moving it to f96 did you still use the 10 amp fuses? The only issue I might have is a little condensation in the passenger side. I washed my truck and noticed it in the bottom right corner. Super hard to get a picture of but you can see it, it distorts the drls in that corner
I might use a different fuse tap too because I was chilling in the parking lot listening to the radio and thinking man I wish I could turn my drls off lol.[
You could always add the dedicated DRL circuits to your truck if it originally came with Quads. I did on my '15 for my ModifyStreet headlights, even have the option in the 8.4 radio to turn them off completely. The Darla only come on when the truck is in gear and the parking brake is not set. If the plug under the fuse box has pins 8 & 23 populated from the BCM, then you just need to contact M² Mods for the extended pigtails for the DRL circuits then enable them using AlfaOBD.
